flywheel? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 12-10-2009, 04:46 PM Thread Starter
deezbalz's Avatar
flywheel?
so last night i pull into my shop to warm up my work truck and when i get out of mine i put it in nuetral and hear a ticking or tapping type noise. at first i thaught it was a injector or something in the engine. but then i put the clutch in and the sound went away and it only does it once you drive 10 miles or so once everything is warm. could this be my flywheel and if so how much longer do i have before it busts completly
2000 f-350 ext cab 6ft bed, beans idm, wicked wheel, fpr shimmed, 6637 intake, 5 inch straight pipe, stage one injectors, beans tuned
deezbalz is offline
post #2 of 7 (permalink) Old 12-10-2009, 04:49 PM
itsjusmoney's Avatar
Re: flywheel?
i would say it is the input shaft bearing and i don't know how long you have. i know a few people that just drive like that and won't fix it but it can't be good
SOLD-2000 f-250 175cc single shot's, 38r, cfm spider, ts chip with custom tunes, southbend con ofe, single 7in stack, 35's on 17's, and a heavy foot
04 lb7 htt366, AD II 165gph, EFI live, ATS stage 3, we'll see what it does this summer i was pulling 1.6x 60ft times last summer running low 13's before the turbo.
itsjusmoney is offline
post #3 of 7 (permalink) Old 12-10-2009, 04:50 PM
Science rulz
Coltaine's Avatar
Send a message via AIM to Coltaine
Re: flywheel?
Well, it'll eventually seize up and destroy your pressure plate, but usually they last like that for quite a while..
One of them truckless bastards.
Coltaine is offline
post #4 of 7 (permalink) Old 12-10-2009, 04:51 PM Thread Starter
deezbalz's Avatar
Re: flywheel?
whats the price of that?
deezbalz is offline
post #5 of 7 (permalink) Old 12-10-2009, 05:43 PM Thread Starter
deezbalz's Avatar
Re: flywheel?
what about throw out bearing
deezbalz is offline
post #6 of 7 (permalink) Old 12-10-2009, 06:06 PM
Science rulz
Coltaine's Avatar
Re: flywheel?
I think maybe me and it'sjustmoney are talking about two different things, my bad.
Been a while since I played with manual transmissions, most commonly the clutch release bearing is the thing that fail.
But as I redid my homework I remember that they usually "warble" when you release the clutchpedal..
Coltaine is offline
post #7 of 7 (permalink) Old 12-13-2009, 08:38 PM
Re: flywheel?
yea two different things i would say its the input shaft bearing and while you have it out you mise well replace the throw out bearing and pilot bushing and maybe even the rear main not a common problem on the 7.3's but it's worth lookin at to see if it's seeping. just my .02
