Bending pressure plate back? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 12-09-2009, 04:33 AM Thread Starter
Clouse2411's Avatar
Send a message via AIM to Clouse2411 Send a message via Yahoo to Clouse2411
Couple nights ago I just got my clutch done went to fire it up and it was grinding. I look and my slave cylinder pushed my throw out bearing fork too far and the fork is all bent and cracked. My question is: Can I bend the fins back on the pressure plate without having any problems?
I'll be pulling the tranny out within the next 2 days and I'll grab some pictures.
97 F-350 RC LB.
Farmer's 400/400, Irate T-4 Mount And Regulated Return, Bullseye S475, ARP Main And Headstuds, Valair Double Disc, Intercooled, Short Throw Shifter, 4in Lift, Hood Stack, Black Interior, Autometer Gauges, Scan Gauge, Front And Rear Diff Covers, Dodge Tow Mirrors, 36x15.50x18 ATZs
Clouse2411 is offline
post #2 of 7 (permalink) Old 12-09-2009, 04:56 AM
PSA
mclean's Avatar
Re: Bending pressure plate back?
the fins on the pressure plate?
or do you mean can u straighten out the clutch fork and reuse it
mclean is offline
post #3 of 7 (permalink) Old 12-09-2009, 11:22 AM Thread Starter
Clouse2411's Avatar
I mean the fins on the pressure plate. The fork is pretty much junk.
97 F-350 RC LB.
post #4 of 7 (permalink) Old 12-09-2009, 11:31 AM
FREE THINKER
Chip's Avatar
you can try but i think you will have issues....i would say replaceing it is the way to go.
1999 7.3, 2wd ,auto
Chip is offline
post #5 of 7 (permalink) Old 12-13-2009, 03:27 AM
tbolt's Avatar
I don't think I would reuse that plate.
Glen
early99 f350 cc, lb, 2wd, drw, A pillar autometer guages, CTS monitor, AIS intake, 4" turbo back cat delete diamondeye exhaust, dptuner, pmt1, jw vb, Swamps ab inj, Adrenaline oil, Coolingmist, 180*T, Trucool cooler, spin on trans filter, Firestone air bags, 2" frt leveling kit, now chased by a 34' toyhauler
tbolt is offline
post #6 of 7 (permalink) Old 12-15-2009, 03:26 AM Thread Starter
Clouse2411's Avatar
Well i replaced the pressure plate and the clutch with a ceramic one from NAPA. Hopefully will last longer than the other one, put in a year ago.
97 F-350 RC LB.
post #7 of 7 (permalink) Old 12-15-2009, 07:08 PM
tbolt's Avatar
Good luck. For the past few years my opinion of napa is about the same as the discount parts stores. A few months ago a bought new rotors for my 99 from napa and guess what? on the box was "MADE IN CHINA". The same box, label as the ones from Auto Zone. I'm starting to use oem from dealer more often. I opened a parts acct at a local Ford dealer with a connection inside and my pricing is about the same as the discount stores and napa. It's hard to get quality unless you go oem nowdays. Or aftermarket which can get spendy.
From your avatar you might want a good aftermarket one!!!!
Glen
tbolt is offline
