Att. Mark Kovalsky - PowerStrokeNation : Ford Powerstroke Diesel Forum
 5Likes
  • 1 Post By Mark Kovalsky
  • 4 Post By Zmann
post #1 of 6 (permalink) Old 01-03-2016, 03:39 AM Thread Starter
Att. Mark Kovalsky
Hi Mark I`ve been reading some threads about swapping a 4R100 in my OBS. They did not say how there torque locked up and they changed nothing in the 4R100 they installed. Could you please tell me if this harsh TC lock up has to do with a PWM lock up or an NON PWM lock up. It looks like they used a stock or a built 4R100 with no changes.
Thanks Bill McIntire
97 F250 7.3 PSD SCLB 4x4 4.10L AUTO, DIAMOND EYE EXHAUST,,DIY 6637. E99 intercooler. 01 4R100 (Built), PCM DPC 422, D-66, 180/80 injectors, T-500 HPOP, E-fuel, DP-tuner F6 V2 chip with Jodys tunes, 290,000 and still going strong. Also live tuned by Jody
BillMcIntire is offline
post #2 of 6 (permalink) Old 01-03-2016, 01:06 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: Att. Mark Kovalsky
The OBS and the early '99 used a NON-PWM lockup. The late '99 until the end of the 4R100 used PWM lockup.
If you put a PWM transmission where a non-PWM used to be the lockup is going to be very harsh. There is an orifice in the pump body that is either 0.030" or 0.040" (I can't remember which) and it's 0.250 in the PWM trans.
That doesn't seem like a big difference, but you need to look at the percentage difference. That's 1200% larger. that will bring on the converter clutch RIGHT NOW. Normally it takes 1-2 seconds to engage. Maybe they like it like that, or maybe they got lucky and used a trans with the non-PRM orifice.
Zmann likes this.
Mark
Mark Kovalsky is offline
post #3 of 6 (permalink) Old 01-03-2016, 05:12 PM Thread Starter
Hi Mark Transgo makes a kit ( 4R100 Lu ) to change a 2001 to an on/off torque lockup. so if I use this kit and a E4OD or early solenoid body from an E 99 4R100 will this work. and can I just put these parts in my 2001 4R100 without changing anything else.
Thanks Again Bill Mc
post #4 of 6 (permalink) Old 01-03-2016, 08:20 PM
Yes, that will work. You might need to use the earlier TRS, I don't remember if the later one is compatible
Mark
post #5 of 6 (permalink) Old 01-04-2016, 12:45 AM
Administrator
Zmann's Avatar
Kudo's to Mark for apparently being on call now
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #6 of 6 (permalink) Old 01-04-2016, 01:52 AM Thread Starter
Mark Thank You Very Much for your time. Bill
