convertor locking up in reverse! HELP!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 12-08-2009, 01:05 PM Thread Starter
I know nothing...
joedaddy's Avatar
When the trans warms up it locks in reverse and kills the motor. Is this mechanicle or a ele prob?
97' 4x4 auto
Doesn't roll with anyone or tag along to be cool...
joedaddy is offline
post #2 of 12 (permalink) Old 12-08-2009, 01:42 PM
theSLEEPER's Avatar
Re: convertor locking up in reverse! HELP!!
I think mine tried to do this the other day... Subscribing.
theSLEEPER is offline
post #3 of 12 (permalink) Old 12-08-2009, 01:49 PM
Is it a factory tranny? Other than some wiring issues like a short in the lock up circuit it could be front pump and/or torque converter seals leaking by.
It could be caused by a loose transmission filter. you can put a flat magnetic strip in the trans pan below the filter pick up to retain the filter also will help with metal carry over. Ranger A4LD transmission has a good magnet for this.
can'twinforlosing is offline
post #4 of 12 (permalink) Old 12-08-2009, 01:53 PM Thread Starter
I know nothing...
joedaddy's Avatar
Loose filter causing lock-up? Not doubting just sounds weired.
joedaddy is offline
post #5 of 12 (permalink) Old 12-08-2009, 05:03 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Low trans fluid can do it, too. It uses pressure to keep the converter clutch off, if the pressure dips low the clutch drifts on.
Mark Kovalsky is offline
post #6 of 12 (permalink) Old 12-08-2009, 06:02 PM
If the neck drops out of the pickup port, it will suck air..
post #7 of 12 (permalink) Old 12-08-2009, 06:25 PM
PHPDiesel's Avatar
Worst case scenario, weak pump or damaged seals allowing too much pressure drop in reverse.
Cody
PHPDiesel is offline
post #8 of 12 (permalink) Old 12-08-2009, 07:28 PM
woodduck97's Avatar
If the filter drops wouldnt it not go in drive either
1997 Ford F-250 Sleeper Edition
woodduck97 is offline
post #9 of 12 (permalink) Old 12-08-2009, 08:48 PM Thread Starter
I know nothing...
joedaddy's Avatar
I left out the poke but that's where I was heading. The truck runs good in drive, it has been shifting harder though. Could loss of psi cause both?
joedaddy is offline
post #10 of 12 (permalink) Old 12-08-2009, 09:17 PM
Either, Or . You complained of torque converter lock up, those are the possible solutions. Read what Mark said Pressure.
