od light flashen and stuck in 3rd gear - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 12-08-2009, 03:17 AM Thread Starter
what is cause my overdrive button to flash on and off and when i put it in drive it goes to 3rd gear and will not shift down r up and is throwing these codes p0470,p0603,p0743,p0750,p0755,p1754 can anyone help me please
red 99 is offline
post #2 of 5 (permalink) Old 12-08-2009, 03:18 AM
Stroker67's Avatar
Re: od light flashen and stuck in 3rd gear
Usually the OD light flashing indicates a problem with the Transmission, not sure about the codes. im guessing Auto?
Stroker67 is offline
post #3 of 5 (permalink) Old 12-08-2009, 03:19 AM Thread Starter
can anyone help with my problems
red 99 is offline
post #4 of 5 (permalink) Old 12-08-2009, 04:33 AM
your trans is in "limp mode". i dont know the codes but but you more then likely will need to take it in and have the trans rebuilt.
02 f250
countryboyrob is offline
post #5 of 5 (permalink) Old 12-08-2009, 04:03 PM
Failure to Communicate
highfive's Avatar
Trans in limp mode:
Those codes are:
0470 = Exhaust backpressure valve malfunction (assume you have it unplugged?)
0603 = Keep Alive Memory in computer (assume you have a chip?)
0743 = Torque converter clutch electrical solenoid issue(good culprit)
0750 and 0755 Also solenoid malfunctions
1754 = Coast Clutch Solenoid
Since you don't have slip code it seems electrical with all of your solenoid codes so check the electrical connector to the tranny and/or find a solenoid pack to swap out or have tested.
96 F250 CC SB 4x4
DIY or Die Tryin-Fuel, Trans, Lifted and Stroked
highfive is offline
