Won't shift into OD when cold - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 21 (permalink) Old 12-07-2009, 10:26 PM Thread Starter
Resident Curmudgeon
Toybreaker's Avatar
Garage
Send a message via Yahoo to Toybreaker
I have a 2001 4x4 auto. Since it has gotten colder here first thing in the morning (even after sitting and "warming up" for 5-6 minutes) it will not shift into OD for another 4-5 minutes. It was recently rebuilt by a local Trans shop.
I took it back to them, When scanned they told me the solenoid packs were failing. they replaced the solenoids....
Well 4 days later and it still has the same issue.
any thoughts?
2001 F250 XLT 4x4 auto
Toybreaker is offline
post #2 of 21 (permalink) Old 12-07-2009, 11:35 PM
Failure to Communicate
highfive's Avatar
Re: Won't shift into OD when cold
Are you sure it's not just the torque converter not locking?
I don't know if it's all years or not but I know some of them won't lock the converter until the fluid gets to a certain temp possibly 60 degrees I can't recall the spec for sure.
When it's good and cold out mine won't lock until it gets about a mile down the freeway. Tranny isn't going to warm up very fast just sitting in park with the motor running.
It still shifts to OD but the converter doesn't lock in any gear until it warms slightly.
96 F250 CC SB 4x4
DIY or Die Tryin-Fuel, Trans, Lifted and Stroked
highfive is offline
post #3 of 21 (permalink) Old 12-07-2009, 11:46 PM
PSN Pretender
907DAVE's Avatar
Sounds normal.
907DAVE is offline
post #4 of 21 (permalink) Old 12-08-2009, 01:16 AM
Stone Crusher
trackspeeder's Avatar
X 2
01 F250 XLT 4X4 Auto trans, Dark Highland Green, Green fuzzy dice,Di Pricol Optix gauges,Dura Lite air cleaner,CCV mod,coolant filter,,AIC,XM Satilite radio.
trackspeeder is offline
post #5 of 21 (permalink) Old 12-08-2009, 01:19 AM
WHAT???
STROKIN N STYLE's Avatar
yea.. what they said
2000 F-250 ex sb 4x4 Swamped 7.3 (CR coming soon)
1999 F-450 cc fb 4x4 Swamped 7.3 (STOLEN)
2008 F-250 cc sb 4x4 H&S, S&B, 5", BMF, Grabbers
STROKIN N STYLE is offline
post #6 of 21 (permalink) Old 12-08-2009, 04:46 AM
tbolt's Avatar
my early 99 does that, always has.
Glen
early99 f350 cc, lb, 2wd, drw, A pillar autometer guages, CTS monitor, AIS intake, 4" turbo back cat delete diamondeye exhaust, dptuner, pmt1, jw vb, Swamps ab inj, Adrenaline oil, Coolingmist, 180*T, Trucool cooler, spin on trans filter, Firestone air bags, 2" frt leveling kit, now chased by a 34' toyhauler
tbolt is offline
post #7 of 21 (permalink) Old 12-08-2009, 04:52 AM
its the TC not locking due to it being cold and totally normal.
02 f250
countryboyrob is offline
post #8 of 21 (permalink) Old 12-08-2009, 05:10 AM
OBS junkie
Cat_Rebel's Avatar
Every truck I've seen with a E4OD/4R100 does it, it's the converter not OD.
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #9 of 21 (permalink) Old 12-08-2009, 10:06 AM
It's a saftey feature program into all manufactures O.D. Trans, all the way back into the early 90's.
01' F250 PSD CC 4x4, GTP38R, Hi-Flow outlet, DI Bellowed up-pipes, BTS Hpop, DI Regulated return, ITP Annilator, AM 3pod, AFE PG7 Stage II, Silverline 4in T-Back, 6.0 Trans cooler, Dp F5, BTS Trans, True-Trac 3.73, Powerslot Cryo, Rotella ELC, Nitto Terra 285/75/16E on Alcoa wheels
Torque37 is offline
post #10 of 21 (permalink) Old 12-08-2009, 01:29 PM Thread Starter
Resident Curmudgeon
Toybreaker's Avatar
Garage
I know the difference between 3rd gear and 4th gear. tq locking and not locking. The freaking thing does not shift into 4th gear.
