Trans temp sender size? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 12-03-2009, 10:14 PM Thread Starter
peterbilt'in
Rob02F350's Avatar
hey
what size is the port plug tap?
i need to buy a temp sender so i can have all the gauges working, but i cant find what size the hole is.... 1/4NPT ? 3/8NPT?
thanks
-Rob
2002 F350 extended cab XLT, 4x4 auto,194K mi @ 10/25/13, ELF7405, DP F5, ultra light gauges, all kinds of "improvements" Yukon Grizzly locker 6K helper springs, x code fronts. 2 Y2K jetta Tdi. RC2 tuned
Rob02F350 is offline
post #2 of 5 (permalink) Old 12-03-2009, 10:19 PM
A Ghost these days...
farm boy's Avatar
Re: Trans temp sender size?
Im not an expert, but I believe you need to buy the sender that is specific to your brand of gauges. I would ask Autometer if they could get you one. They might be all universal though. Good luck.
2002 F-250 4X4 Flatbed
~Cryo'd Forged Rods ~Comp 910's ~DI Push Rods ~ARP Studs ~IH Up-pipes ~GTP38R/1.15 ~238/80's ~Fuelab ~Built Auto ~Matt's Tunes ~Water Inj. ~Gooseneck Brand Flatbed
Rockin' Out with some help from: Alpine / Rockford Fosgate / Memphis / Infinity
farm boy is offline
post #3 of 5 (permalink) Old 12-03-2009, 10:55 PM Thread Starter
peterbilt'in
Rob02F350's Avatar
yeah, the senders are universal.
i brought in my autometer one to my work to try and find the dam nipple that screws into the ehxaust, well needless to say i had to buy another pyrometer just for the nipple. even had the same part number on it as the CAT and Paccar ones.
so im going to assume the temp senders are the same also, venerable resistance by temperature.
just need to know what size to get, the transmission ones are probably 3/8" npt, where as the rear's are 1/2npt
post #4 of 5 (permalink) Old 12-04-2009, 12:21 AM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
The test port in the side of the transmission is 1/8" NPT dryseal thread.
Mark Kovalsky is offline
post #5 of 5 (permalink) Old 12-04-2009, 01:33 AM Thread Starter
peterbilt'in
Rob02F350's Avatar
1/8, got it.
thanks mark.
