idi trans - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 12-03-2009, 01:54 AM Thread Starter
<--losser
fordbidden's Avatar
idi trans
what trans would be in a 1988 idi? and how could i make he sifts a little smoother?
F-250 7.3L 2wd manual 5 speed, turbo, chip, custom exhaust
fordbidden is offline
post #2 of 12 (permalink) Old 12-03-2009, 02:55 AM
oilfield trucker
zpilgeram's Avatar
Re: idi trans
You would have the E4OD, unless by shifting smoother you mean your dumping the clutch,in which case you would have the zf5.
96cc,lb,4x4,zf5. DIY dual filter intake, intercooled,gauges,4''down pipe, DIY front bumper/grill guard,fuel tank mod, 238cc Rosewood Diesel hybrids,6pos chip from TDP,
stealth SRP1 HPOP,Garrett GT4294 with DIY mounting kit,valair 500hp kevlar/ceramic clutch,Dual SD pumps electric fuel system with regulated return,5'' DIY Straight pipe.
zpilgeram is offline
post #3 of 12 (permalink) Old 12-03-2009, 05:09 AM
OBS junkie
Cat_Rebel's Avatar
Re: idi trans
Might be the pre E4OD the AOD. Is it a 3sp or does it have OD?
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #4 of 12 (permalink) Old 12-03-2009, 04:09 PM Thread Starter
<--losser
fordbidden's Avatar
Re: idi trans
well its an auto so im not sure how i am dumping the clutch. i dont drive it cause none of the guages work and i am afraid it won't make it home quite yet so im not sure if it has over drive or not.
post #5 of 12 (permalink) Old 12-03-2009, 04:31 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: idi trans
The AOD was never installed with an IDI. It could be either an E4OD or a C6. Does it have an OD OFF button on the dash?
Mark Kovalsky is offline
post #6 of 12 (permalink) Old 12-04-2009, 12:28 AM Thread Starter
<--losser
fordbidden's Avatar
Re: idi trans
well i took it for a drive today, and i made it back. It is only a three speed, and there is no over drive button on the dash. It doesn't want to shift so i am not sure what to do, or if that can be fixed at all.
post #7 of 12 (permalink) Old 12-05-2009, 12:25 AM
Re: idi trans
It's a C6. Of course it can be fixed. It's just a question of what's wrong and how expensive it is to fix.
post #8 of 12 (permalink) Old 12-05-2009, 02:40 AM Thread Starter
<--losser
fordbidden's Avatar
Re: idi trans
o no i hate those words, the expensive part. i am a transmission idiot, just like all other things automotive.
post #9 of 12 (permalink) Old 12-05-2009, 04:25 AM
OBS junkie
Cat_Rebel's Avatar
Re: idi trans
C6s are not hard to fix & parts tend to be reasonably priced.
RIP Will Iott
post #10 of 12 (permalink) Old 12-05-2009, 01:52 PM Thread Starter
<--losser
fordbidden's Avatar
Re: idi trans
all right. so it slams into gear, when it shifts. it just really doesn't want to shift up. what does that mean, what needs to be fixed becuase i just don't know.
