Shift points '08 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 11-25-2015, 11:12 AM Thread Starter
mlec15016's Avatar
Shift points '08
I have an '08 w the 6.4 just under 91000 miles. I just bought it a couple months ago. I did the dpf delete and I'm using the Gearbox Z dpf-r+ tune. I have their Electron monitor as well. Truck runs great and shifts great 99% of the time. The issue I'm having is I feel it goes into higher gear too soon, and unless I really plant the throttle it doesn't downshift. Any ideas or suggestions on this? Is it a common thing? I don't know when or even if the trans was serviced, I'm doing that this weekend. I don't know if this will help though. Thanks
mlec15016 is offline
post #2 of 4 (permalink) Old 11-25-2015, 12:46 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: Shift points '08
Servicing the trans is a good thing, but it won't help this. The decision on when to shift, either up or down, is 100% in the computer. The tunes control all of that. Servicing the trans doesn't do anything for the computer.
Mark
Mark Kovalsky is offline
post #3 of 4 (permalink) Old 11-25-2015, 02:49 PM Thread Starter
mlec15016's Avatar
Thanks. Can you recommend any tunes?
post #4 of 4 (permalink) Old 11-25-2015, 06:53 PM
No, I can't. I have never used any, and I don't personally know any of the tuners.
Mark
