Trans troubleshooting - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 25 (permalink) Old 11-28-2009, 10:26 PM Thread Starter
I threw the code for the tq converter slipping the other night, on my first drive with the truck and it went into hard shifting-increased line pressure mode.
I's like to get out of this as cheap as possible, BTS is NOT an option, and i don't think woods is either, loosing the job in jan, so i'd like to save as much money as possible right now.
Here is my plan so far-
- Dump the fluid, if its dark brown, or if there is an excessive amount of metal in the pan, i know its toast, and i have to do a rebuild.
No metal in pan/nice fluid I'll do the following-
- Clean valve body and possibly install a shift kit, any recommendations?
- Replace torque converter and front pump, I see them on ebay for 350 for a TC, and about 150 for a rebuilt pump, this seems to be the cheapest option right now.
I'd like to get at least one season of plowing out of this truck, not planning to do any power upgrades right now, just plan on using it as a money-maker.
Is there a tool list of what i would NEED to rebuild the trans, i know alot of the trans manual have some extra do-dads for troubleshooting and other stuff that can be accomplished with reg tools. Rebuilding a trans is within my mechanical ability, I just need to figure out what tools i need to do them.
Any input is appreciated.
Chop Cut Grind Weld
96 RC 7.3 auto, rebuilt tranny, 3" dp, 4" to the back, PHP hydra, WW2/1.0 housing, stock injectors and hpop, efuel w/bb tightwad reg return, b-codes w/4" lift blocks, 3.5" rsk and x codes, 34.5" tire
ericlouie1 is offline
post #2 of 25 (permalink) Old 11-30-2009, 02:19 AM Thread Starter
Re: Trans troubleshooting
Moot point, trans fluid is a little bit darker than the red on this website, not the nice brite red i was hoping for.
The magnet was quite fuzzy, between 1/8 and 1/4 thick of very fine particles.
No real big chunks in the pan, just a few small unidentifiable material, about the size or cigarette tobacco.
Gotta start rustling up the cash for a rebuild.
No pending codes sitting there idling, cleared the stored codes, and went for a short test drive, nothing came up. yet.
I have to replace the rear driveshaft u-joints, the rear is definitely bad, front i'll do for ####s an giggles.
Once i get the gearbox replaced i'll have a better handle on what else is needed.
Chop Cut Grind Weld
post #3 of 25 (permalink) Old 11-30-2009, 08:01 PM
aklim's Avatar
Is it obvious that you are plowing? I am not sure as to whether Ford will stand behind your trans if it breaks and they know you plow. I suppose if you can disconnect it so it doesn't show and you can be a total moron and just say "I don't know what happened." with the most stupid look you can muster you might just stand a chance getting it fixed should something happen.
No, this didn't happen to me but someone I know and GM fixed it.
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U front and A Rear.
aklim is offline
post #4 of 25 (permalink) Old 11-30-2009, 09:07 PM Thread Starter
No, the truck has never been plowed with. I still haven't put the mount on it.
I'm debating putting myself into a bit of debt, and getting it done right, the first time.
Chop Cut Grind Weld
post #5 of 25 (permalink) Old 11-30-2009, 09:10 PM
aklim's Avatar
IMO, it has been cheaper to do it right the first time than to redo it.
aklim is offline
post #6 of 25 (permalink) Old 12-02-2009, 07:19 AM
Smokin' Ole
Mekanik's Avatar
A trans rebuild kit from SunCoast is around $400. It has beefier friction plates and stronger steels for the clutch plates. That's assuming you're doing it yourself though.
2003 F-350 CCSB 4x4 7.3L Powerstroke, 2.5" leveling kit, 285 BFGoodrich All-Terrain T/A's, Banks Big Hoss chip, K&N Cold Air Intake, 4" Banks Monster Exhaust (soon to be Grand Rock stacks), ISSPRO A-pillar gauges (Pyrometer, Oil temp, Trans temp, Boost)
Mekanik is offline
post #7 of 25 (permalink) Old 12-02-2009, 12:55 PM
aklim's Avatar
Don't forget to add the TC. To the OP. If you do buy that kit, make sure that the builder is ok with it unless you DIY. In fact, buy it thru the builder otherwise, if a problem occurs, well.......
aklim is offline
post #8 of 25 (permalink) Old 12-03-2009, 09:56 AM Thread Starter
Anybody know what special tools I need to do a rebuild?
Chop Cut Grind Weld
post #9 of 25 (permalink) Old 12-03-2009, 02:30 PM
aklim's Avatar
I would take a class at a local tech college and use their equipment and learn what to do. Otherwise, why buy any special equipment if you are using it once in several years?
aklim is offline
post #10 of 25 (permalink) Old 12-04-2009, 10:44 PM Thread Starter
good call.
Chop Cut Grind Weld
