swaping tranny from ground whos done it - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 11-26-2009, 01:31 PM Thread Starter
got boost
Send a message via AIM to Lmgrcivic
Well Im getting ready to swap in the new tranny and I dont have access to a lift this time. I was just looking for some tips or advice from people that have had to do it this way before. Thanks in advance
01 Black 4dr auto, 118k, BTS trans, RR fuel system, DIY intake, 5in exhaust, CCV, zoodad, non EBV pedestal, high flow outlet, DP-tuner 60hptow, 80hp econo, 100hp per, 120hp race, SS oil crossover line, boost tube, map sensor, IH cps, gauges, RC leveling kit w/leaf springs
94 Civic LS motor turbo'd 11.6 @ 120 14psi stock block
Lmgrcivic is offline
post #2 of 12 (permalink) Old 11-26-2009, 02:09 PM
Re: swaping tranny from ground whos done it
Do it this way all the time its always good to have a trans jack. i dont at home and thats were I do must of my trans work any ways but if you dont just get a normal floor jack and some wood so you dont damge it and cut the boards down so they dont get caught on eney thing and it is a must to have more than one person doing it this way just to be safe. Eney questions just ask me good luck.
f250 hd Powerstroke is offline
post #3 of 12 (permalink) Old 11-26-2009, 02:39 PM
The Fireman
big_stroker's Avatar
I did it not to hard get a tranny jack or atv jack
big_stroker is offline
post #4 of 12 (permalink) Old 11-26-2009, 02:39 PM
<--Spy Vs. Spy
theSLEEPER's Avatar
I used ratchet straps wraped once around the trans and over the frame rails. It worked awesome.
228-365-0698
Sheep only have two speeds, 'grazing' and 'stampede'.
Regulated Returns are on SALE!!
theSLEEPER is offline
post #5 of 12 (permalink) Old 11-26-2009, 03:09 PM Thread Starter
got boost
sounds good thanks guys. never thought about the rachet straps and was thinking about buying the tranny jack.
do any of you lift the truck off the ground any cause my truck isnt lifted at all so its not to high. just wondering if it would make it easier
thanks again
post #6 of 12 (permalink) Old 11-26-2009, 03:13 PM
deffinately buy the jack. other than that its pretty straight forwad
PMRCM#1
slowleak is offline
post #7 of 12 (permalink) Old 11-26-2009, 03:14 PM
You could rent a trannyjack from a rental store???
Sea97Stroker is offline
post #8 of 12 (permalink) Old 11-26-2009, 04:09 PM
ADubDiesel's Avatar
A floor jack and a 2x8 works well too if you have a second person to help balance it. I've done this a few times. I'm always on a budget...
1995 Ford F-250 7.3 (Sold)
1998 Nissan Maxima 3.0
ADubDiesel is offline
post #9 of 12 (permalink) Old 11-26-2009, 04:17 PM
kampinguru's Avatar
Just jack the rear of the truck up as high as you can.
2000 F250 Lariat S/C SB 4X4 Off-Road
7.3L PSD
2005 Cedar Creek 30RLBS
PullRite Superglide Hitch
Firestone Ride-Rite Airbags and Dual Commander II
ATS turbo housing
AFE Stage 2 intake with PG7 filter and sock.
DP Tuner 40tow, 80 econ, 100 Race
BTS transmission April 09
Magnaflow 4" turbo back exhaust
kampinguru is offline
post #10 of 12 (permalink) Old 11-26-2009, 07:06 PM Thread Starter
got boost
Jack it up in the rear wouldn't that make it hard to pull it off and slide it on.
