Idea For A Trans Mod... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 11-23-2009, 05:57 PM Thread Starter
<--Spy Vs. Spy
theSLEEPER's Avatar
Would it be possible to eliminate the signal that the trans recieves to "kick down" a gear?
Such as a switch that could be thrown in 3rd at low rpm to cancel out the downshift? I'm just wondering, because I know it can be done with tuning, but it's not always beneficial to have something like that, but it'd be nice from time to time...
Is there a signal that is given that could be interrupted? Or is it all TPS based in the PCM?
228-365-0698
Sheep only have two speeds, 'grazing' and 'stampede'.
Regulated Returns are on SALE!!
theSLEEPER is offline
post #2 of 10 (permalink) Old 11-23-2009, 06:13 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: Idea For A Trans Mod...
Downshifting is a function of vehicle speed and pedal position. There is no "kickdown" signal. I don't know how to do what you are proposing, except for a custom tune.
Mark Kovalsky is offline
post #3 of 10 (permalink) Old 11-23-2009, 06:19 PM Thread Starter
<--Spy Vs. Spy
theSLEEPER's Avatar
Ok. Thanks. I figured that'd be the case, but no harm in asking.... Guess that'd be what a "dyno" tune would be for....
228-365-0698
post #4 of 10 (permalink) Old 12-02-2009, 09:52 PM
TRX370r's Avatar
Jody had my 80 tow tune set-up to where it wouldn't down shift from 3rd to 2nd unless you were really going slow or had a ton of peddle in it. I usually pulled it down manually. It worked good for me so I know what your asking.
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government.
Thomas Jefferson
Beans Diesel Performance
TRX370r is offline
post #5 of 10 (permalink) Old 12-09-2009, 01:35 AM
secondarychaos's Avatar
couldn't you do a TC lockup switch? as in, wouldn't the computer see that it's locked and not try to downshift?
Dan
96 Powerstroke: 6637, downpipe to dump exhaust, 140v IDM and a shift kit.
84 Honda Sabre V65 1100: pipes, jet kit and new tires. Faster than I think I'll ever need.
secondarychaos is offline
post #6 of 10 (permalink) Old 12-09-2009, 01:47 AM
Snake Oil Salesman
mattr66's Avatar
Just have a different file that acts the way you want it to and switch to it....
Matt Robinson
Gearhead Automotive Performance
Originally Posted by PSDPlayer View Post
If you have nozzles that were Extrude honed over and over and over again. It will look like a porn stars ass.hole where the pintle is supposed to seal.
mattr66 is offline
post #7 of 10 (permalink) Old 12-09-2009, 02:17 AM Thread Starter
<--Spy Vs. Spy
theSLEEPER's Avatar
No. The trans still works the same with the TC locked. It'll kick down and shift up just the same.
And Matt. I knew that was an option. I was just wondering if my idea was possible. As in interrupting the "kickdown" signal on demand. I figured it was worth a shot at asking. But it's not possible, so if I really wanted a tune like that, I guess I'd just have to order one.
Could you build a tune that only kicks each gear down based off of vehicle speed?
That way it'd work fine as far as slowing to a stop, and then climb through the gears, but you could give any amount of throttle input and it would not "kick down". Only downshift under a coasting condition and under a given speed per gear?
I don't need this, I'm just wondering if it is within the realm of a stock PCM's shift tuning ability. Or if you would need something like PCS for that type of control.
228-365-0698
post #8 of 10 (permalink) Old 12-09-2009, 03:57 AM
Snake Oil Salesman
mattr66's Avatar
Although somewhat cryptic, it can be done with the factory PCM.
Matt Robinson
mattr66 is offline
post #9 of 10 (permalink) Old 12-09-2009, 04:10 AM
just a welding fool.
Hawker's Avatar
if it can be done with a tuner, i wouldn't see how it couldn't be done by interupting or fooling the shift solenoids.i couldn't really say how a factory PCM would act, but you would essentially be choosing the gear you wanted based on the shift solenoid signal.
when i was in the beginning stages of swapping to an automatic, and before running an entire engine harness and factory PCM, we were able to command different gears based on an on or off signal by jumping a live wire to that solenoid. sounds pretty basic, but it's something my dumb ass would start an idea from...
now that i'm thinkin about that, didn't charles come up with a shift set up like that, even though he had a PCS stand alone...
Swamps
Gearhead Tuning
Diesel Innovations
Hawker is offline
post #10 of 10 (permalink) Old 12-09-2009, 04:16 AM
Snake Oil Salesman
mattr66's Avatar
The PCS has a nice digital UP/DOWN input function that the factory can't do.
Matt Robinson
mattr66 is offline
