VB line pressure? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 11-23-2009, 12:24 AM Thread Starter
Metal - It kicks your ass
VB line pressure?
Right now when i hook it up to a pressure tester i can get about 10psi. The shifts are crisp and clean.
After a couple of hours the shifts start to get sloppy and slide into gear. At this point i get around 6psi.
I am losing pressure somewhere and dont know why. I have a new valve body, tugger shift kit, new clutch packs, brand new build. Hav'nt gotten to drive it much yet. Any suggestion's or trouble shooting to cure my problems.
Modded L99
dirtboy25 is offline
post #2 of 6 (permalink) Old 11-23-2009, 12:55 AM Thread Starter
Re: VB line pressure?
Anybody????
Modded L99
post #3 of 6 (permalink) Old 11-23-2009, 12:59 AM
Failure to Communicate
highfive's Avatar
10PSI? That can't be right, where are you testing it? in the pressure port on the side?
10psi isn't gonna hold much, pressure specs are in the transgo manual if you have it from the tugger install.
96 F250 CC SB 4x4
DIY or Die Tryin-Fuel, Trans, Lifted and Stroked
highfive is offline
post #4 of 6 (permalink) Old 11-23-2009, 01:03 AM Thread Starter
the builder told me it was getting 10psi when he hooked it up. I dont personally check it nor do i know where it should be. I just took it forgranted he knew what should be right. I took it back and he is going to do some adjusting on it. And those reading are coming without my chip installed. He is supposed to call transgo in the morning and deliver it back to me.
Modded L99
post #5 of 6 (permalink) Old 11-23-2009, 12:51 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
There are two places that one could measure pressure. The test port on the side of the trans reads line pressure. That should be between 65 PSI and 330 PSI depending on operating conditions.
One could also read pressure in the cooler lines, though I don't know what that would show. Those pressures could be anywhere from 0 to about 40 PSI.
Mark Kovalsky is offline
post #6 of 6 (permalink) Old 11-23-2009, 07:52 PM
highfive's Avatar
Specs I used:
Gear Range-------- at Idle Hot-----------at Stall Hot
Park&Neutral--------55-70 PSI--------------N/A-------
Reverse-------------75-130 PSI-----------240-265 PSI
Drive---------------55-70 PSI------------156-174 PSI
2nd-----------------55-70 PSI------------156-174 PSI
1st----------------75-99 PSI------------157-186 PSI
96 F250 CC SB 4x4
highfive is offline
