SD 6 Speed into a 97 OBS??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 11-22-2009, 10:45 PM Thread Starter
I have read that it hits the firewall somewhere, does anyone know exactly where it hits. I have heard a 1 inch body lift will solve the problem. Has anyone done the swap that could give me some pointers on what all needs done?? The trans is a 99 SD 6 speed and Transfer case.
Sea97Stroker is offline
post #2 of 8 (permalink) Old 11-22-2009, 11:05 PM
bobvillaoftn's Avatar
Re: SD 6 Speed into a 97 OBS???
i dont know about the firewall, i pondered the swap and was told that the trans. tunnel would have to be modded, different drivelines, yadda yadda. im sure some1 will point you in the right direction though.
05 f350 CCLB 4x4 delete and sct x4 thanks to innovative
Originally Posted by RedSmokey View Post
Sh*t in a box (litterally) and write "Will give you 200+ hp, just add to your fuel" on the box and give it to him. Then ask him if he still believe's everything thats written on a box...
Originally Posted by bruce51d View Post
if you can blow up a 7.3 just imagaine what you would do to a 6.0
bobvillaoftn is offline
post #3 of 8 (permalink) Old 11-22-2009, 11:34 PM Thread Starter
From doing research ...the 2wd is the truck that needs firewall mods. Man I wish someone had a write up on doing this..
post #4 of 8 (permalink) Old 11-23-2009, 01:10 AM
do the swap then do the write up.
i know if i come across a 4r100 im gonna swap it into my obs
02 f250
countryboyrob is offline
post #5 of 8 (permalink) Old 11-23-2009, 01:10 AM
Team Shade-Tree Mechanic
Mini-Stroke...'s Avatar
Send a message via AIM to Mini-Stroke...
There are a few threads on here about this, check on the 1994- 1997 OBS section
96 PSD 4X4, 33's, intake, 4" straight exhaust, Autometer NV gauges, Edge
, ZF5 tranny, LUK clutch. D60 swap in the works......
87 Diesel ranger 4X4
Mini-Stroke... is offline
post #6 of 8 (permalink) Old 11-24-2009, 07:25 PM
Cowboy Up
I did the swap. I think it is alot better set up.
'96 F350 CCLB, Dually, 4wd, ZF6, 4.10's, 4" lift, Energy suspension and body bushings, Firestone airbags, 245/70R19.5, 3" DP, 4" MBRP straight pipe, Afe stage 2, TW 6 pos, Autometer gauges, Valair kevlar/ceramic clutch, Stage 1's, Shimmed FPR, Gutted EBPV, Welded pedestal, CCV mod, SD 7.3 intercooler, D66 Turbo, 17* HPOP
INTPSTROKE96 is offline
post #7 of 8 (permalink) Old 11-24-2009, 07:27 PM
cattle farmer
powerstroke742008's Avatar
someone on the org. did it also
Thomas,
97 f350 cclb-7.3
sticks,clutch,bars
05 f350 cclb-6.0
deleted, studed
powerstroke742008 is offline
post #8 of 8 (permalink) Old 11-24-2009, 09:29 PM
Cowboy Up
I had a ZF5 to start with though
