4r100 into obs - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 10-09-2015, 02:57 PM Thread Starter
Justaworktruck
John Martens's Avatar
4r100 into obs
Did the swap and nothing happens when cycling through any gears on shift lever.
Have compushift tranny controller so did not swap solenoid pack.
Any ideas??
Pullinweight
1997 f250,03 cummins, HE351 turbo,van Aiken tuner, cobalt gauges, fass fuel,NADP 4r100, compushift tranny controller, air ride suspension, 05 axle swap, hydra boost upgrade
John Martens is offline
post #2 of 7 (permalink) Old 10-09-2015, 03:22 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: 4r100 into obs
The linkage may not be connected, either inside or outside of the trans.
Mark
Mark Kovalsky is offline
post #3 of 7 (permalink) Old 10-09-2015, 06:36 PM Thread Starter
Justaworktruck
Re: 4r100 into obs
We changed outside shaft and linkage, but not inside linkage. In my mind, without even tranny controller it should try to back up or go forward.
Pullinweight
post #4 of 7 (permalink) Old 10-10-2015, 11:01 AM
Re: 4r100 into obs
Yes it will. With no electronics connected it will engage and drive forward or reverse.
Put a 0-350 PSI gauge in the test port of the trans. What pressures do you get in each PRNDL position?
Mark
post #5 of 7 (permalink) Old 10-13-2015, 02:35 PM Thread Starter
Justaworktruck
Re: 4r100 into obs
We haven't got a psi gauge yet, but we opened up the e4od pan and we cannot see a difference in the shift lever. Where is the difference?
I see they both push in the "piston" to shift from park to drive and so on.
Tried cycling column shift lever. Its like its in neutral or park all the time.
Quite stumped at this point.
Pullinweight
post #6 of 7 (permalink) Old 10-14-2015, 01:07 AM
97-7.3powerstroke's Avatar
Re: 4r100 into obs
Is the transfer case in neutral? It's something simple but figured it's easily overlooked.
97-7.3powerstroke is offline
post #7 of 7 (permalink) Old 10-14-2015, 02:55 PM Thread Starter
Justaworktruck
Re: 4r100 into obs
No it isn't, but we found the problem. The pump shaft had not been put in tranny. Rebuilder put it to the side and the installer didn't take the old/previous one out of the original tranny.
Pullinweight
