Aftermarket Torque Converter ?'s - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 09-26-2015, 07:34 PM Thread Starter
wizbangdoodle's Avatar
I am in the middle of rebuilding my 6.4 and found that the crank thrust bearing was shot. From what people tell me, that is caused by the crank "walking". Most people agree that it is probably a transmission problem with the torque converter being the #1 culprit. This makes sense to me because if the TC was ballooning, it would do exactly that, push on the crank and cause thrust bearing failure.
So the question I need to ask is, what aftermarket TC should I get? I have looked at BD, ATS, Suncoast etc. There seems to be a small difference in price between all these TC's (couple hundred bucks). Is there one that stands out among the rest or would I be good with just about any high quality TC from any of these guys? Also, does anyone know what stock stall is on the 5R110 TC?
wizbangdoodle is offline
post #2 of 6 (permalink) Old 09-26-2015, 08:11 PM
Strokin all day
Spence's Avatar
Re: Aftermarket Torque Converter ?'s
I'd go with a suncoast. I've never heard a good word about anything ats to be honest but never had any personal experience with them. What hp you shooting for it to hold.
Might want to think about a billet input shaft and make sure your clutch packs are in good shape. The 5r110 have great clutches but I've heard there input shafts aren't the strongest.
08 F350 Spartan tuned, egr delete, 5 in turbo back, no limit cai, ccv, cac pipe, bd 6.0 manifolds, bd up pipes, coolant filter.
3 vehicles in the scrap yard.
1 cummins sold to some boner next town over.
Spence is offline
post #3 of 6 (permalink) Old 09-26-2015, 09:28 PM Thread Starter
Well, the tranny was replaced 50k ago after running an Innovative tune for 25k. My tech guessed the tune tore up the transmission. It never did shift right and I could never get them to call me back, so I gave up.
Power level is relatively mild, running a KEM tune now, which seems to shift MUCH better. I daily drive the truck for work (empty), but do tow a very large 5th wheel for camping. Just want this thing to be dead reliable and tow with no worries.
After reading some various threads here and there, I've heard some people comment about ordering 3 disc TC's and only getting 1 disc. Anyone get ripped off like that?
post #4 of 6 (permalink) Old 09-26-2015, 10:33 PM
Strokin all day
Spence's Avatar
River city also has one with a 1600 stall speed. To answer your other question stock stall is 1800 I believe. And I'd think with a reputable shop like suncoast if they did ship you a single disc instead of the triple it would have been by mistake and I'm sure they'd make it right. I'd still consider the input which I'm sure suncoast could help you out there too. By the way I'm not trying to say any of these other places don't make quality tcs but suncoast is known for transmissions. I'd buy from them just like I'd buy from south bend clutch for a manual cause that's what they do you know.
Spence is offline
post #5 of 6 (permalink) Old 09-26-2015, 10:46 PM Thread Starter
Thanks for the info. I know that Suncoast has a great reputation and I almost went with a Suncoast transmission about 4 years ago when mine went belly up. Just couldn't justify the cost at the time.
post #6 of 6 (permalink) Old 09-27-2015, 12:17 AM
Strokin all day
Spence's Avatar
No problem. And yeah its an expensive trigger to pull but worth it. Good luck with it. Post up what you eventually get and how it works with your setup.
Spence is offline
