4R100 wont engage Drive unless reved every time - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 11-19-2009, 07:34 PM Thread Starter
2002 F450. The 4r100 trans has been doing this for 20k miles. Does not matter if warm or cold. Can drive it 400 miles and it will do it instantly. The issue is if you put the trans in Drive (or 1st) it does not engage and needs reved to 1,500- 2,000 RPM and then engages. From then on as long as you donít shift out of Drive it stays engaged. If you shift to R and back it needs reved. I have pulled 15,000 lb. loads 800 miles miltiple times and hauled 20-30 cars behind this truck over the past few years with it this way. It has not changed. Also, Reverse engages instantly even when cold. Any ideas? I know if I take it to a trans shop they are going to say it needs rebuilt and it will be $4,000.
PCweber is offline
post #2 of 7 (permalink) Old 11-19-2009, 07:38 PM
Re: 4R100 wont engage Drive unless reved every time
STUPID QUESTION BUT HAVE YOU CHECKED THE FLUID LEVEL?
01 c/c sb 8 inch lift 39.5 swampers (ON THE ROAD AGAIN)
00 F450 (SOLD)
newest addition 06 F150 (STOCK)SSHHHHHH don't tell her its a work truck!
hold my beer & watch this sh1t!!
8inchstroker is offline
post #3 of 7 (permalink) Old 11-20-2009, 08:12 PM Thread Starter
Affirmative. It is a tad over full even.
PCweber is offline
post #4 of 7 (permalink) Old 11-20-2009, 08:19 PM
woodduck97's Avatar
I dont have any idea on what is going on but if you plan on getting a trannsmisson give BTS transmisson a call or John Woods. They will fix you.
1997 Ford F-250 Sleeper Edition
woodduck97 is offline
post #5 of 7 (permalink) Old 11-26-2009, 02:09 PM
check vacum pump
whit7452 is offline
post #6 of 7 (permalink) Old 11-26-2009, 03:58 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Now you got me curious. How could the vacuum pump be related to the transmission?
Mark Kovalsky is offline
post #7 of 7 (permalink) Old 11-26-2009, 04:03 PM
FREE THINKER
Chip's Avatar
also curious.
1999 7.3, 2wd ,auto
Chip is offline
