broke tranny or transfer case HELP - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 11-19-2009, 07:24 AM Thread Starter
Question broke tranny or transfer case HELP
installed my new dp tuner chip and gauges and desited to test it out in the 140 hp setting i floor it i get up to bout 30mph and i here i snap. truck isent going any were the drive shafts dont spin or any thing what broke?? the tranny or transfer case??? i just had the trany built "bulet proof" https://powerstrokenation.com/forums/...s/confused.gif
slavar17 is offline
post #2 of 15 (permalink) Old 11-19-2009, 03:50 PM
fbilly420's Avatar
Re: broke tranny or transfer case HELP
Have you tried putting it in 4WD? Maybe the t case slipped into neutral? Who did your trans?
2001 F250, CCSB, 4X4, Auto, Forged rods
Lots of go fast parts and still slow.
2001 F250, STD cab, 2WD
Frame is a little shorter now
workin on body
engine build underway
fbilly420 is offline
post #3 of 15 (permalink) Old 11-19-2009, 03:58 PM
Science rulz
Coltaine's Avatar
Send a message via AIM to Coltaine
Do these T-cases have neutral?
Did you check the trans fluid? It should be clear red and not smell burnt.
One of them truckless bastards.
Coltaine is offline
post #4 of 15 (permalink) Old 11-21-2009, 11:22 PM
peterbilt'in
Rob02F350's Avatar
if you have a manual 4x4 engagement, you can select N in the transfer case. with the electronic i dont think you can select N, but it is possible that i can still find it when you dont want it....
if you jack up the rear atleast 1 tire, spin the drive shaft and listen to the transfer case.. if theres no noise or very little. it could of poped into N. try selecting 4wd high... low... then back to high... and 2wd doing the same tests.
2002 F350 extended cab XLT, 4x4 auto,194K mi @ 10/25/13, ELF7405, DP F5, ultra light gauges, all kinds of "improvements" Yukon Grizzly locker 6K helper springs, x code fronts. 2 Y2K jetta Tdi. RC2 tuned
Rob02F350 is offline
post #5 of 15 (permalink) Old 11-22-2009, 10:07 PM Thread Starter
aamco trans acording to them its bullet proof. the t case is the electonic engagment and it dosent have a nuetral the trans oil is fine not burnt or any smell there is no grinding what soever
slavar17 is offline
post #6 of 15 (permalink) Old 11-22-2009, 10:23 PM
Stone Crusher
trackspeeder's Avatar
Input shaft on the tranny.
01 F250 XLT 4X4 Auto trans, Dark Highland Green, Green fuzzy dice,Di Pricol Optix gauges,Dura Lite air cleaner,CCV mod,coolant filter,,AIC,XM Satilite radio.
trackspeeder is offline
post #7 of 15 (permalink) Old 11-22-2009, 10:34 PM
10.61 @ 128 MPH
Powersmoker's Avatar
Send a message via AIM to Powersmoker
broke a input shaft, forward clutch drum or o/d planet. Been there done that
2000 F-250 Regular Cab
1069 RWHP 1768 Torque
10.55 @ 129 MPH NOS
2000 F-350 ECLB DRW
Tow Rig
Murff Racing Twisted Diesel
Empire Diesel DieselSite
Swamps Diesel
Powersmoker is offline
post #8 of 15 (permalink) Old 11-23-2009, 08:40 PM
aklim's Avatar
And I am so hung that it drags an inch above the ground. You really believed them? the only way I would use an Aamco or a Jasper is if I was trying to sell the truck and it broke on me.
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U front and A Rear.
aklim is offline
post #9 of 15 (permalink) Old 11-23-2009, 10:29 PM
AFAIK, it's the same t-case as those with the hand shifter, so technically, there is a neutral. Have you fiddled with the servo buttons on the dash, or better yet, had an assistant do it while you observe under the truck and see if the selector moves? I _think_ you can see it physically moving from the outside of the case. A long-shot, but one you should at least rule out.
madpogue is offline
post #10 of 15 (permalink) Old 11-24-2009, 12:05 AM
peterbilt'in
Rob02F350's Avatar
there right with it being almost bullet proof... but they dont know much at all. i called looking for a viton oring for a fleet truck at work... they said they just use what ever fits from the kit from home depot.
still go threw your self and check whats being suggested.
