factory trans tem gauge? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 11-19-2009, 05:56 AM Thread Starter
edge186's Avatar
So i sold my old pyro and boost gauges the other day and the guy asked why i got new ones. i told him cause i needed a trans temp gauge and wanted to have all matching guages. he said that his 02 came with a factory trans temp guage. is that right? I think he might have just been looking at the engine temp or something.
2001 F-250 PSD 4x4 Lariat CC SB Auto
Power Hungry Performance
Edge CTS Insight
ATS 4" Straight Pipe
ATS Ported Compressor Housing
AFE Stage II Intake
DI Stainless Up-Pipes
BTS Valve Body
6.0 Billet Converter
6.0 32 Row Trans Cooler
Foil Delete
AIH Delete
CCV Mod
Firestone Ride-Rite airbags
edge186 is offline
post #2 of 8 (permalink) Old 11-19-2009, 06:16 AM
Re: factory trans tem gauge?
Mine came with one from the factory but it isn't accurate. More of a dummy light than anything.
02 F-350 7.3
08 F-250 6.4
98 3500 12v
Cppr_Busa is offline
post #3 of 8 (permalink) Old 11-19-2009, 06:22 AM
PSN Mega Miler
crowz's Avatar
2002's have a trans temp gauge. It actually does work unlike the oil pressure one. Its just pretty sluggish about going up compared to what you would get with an aftermarket gauge. You can tell if the trans is getting hot though.
2002 F250 SuperDuty Lariat PSD 7.3 Crew Cab 4x4 302,000+ miles.
, Valvoline Extreme Blue 5w40 Synthetic,
, Clifford Matrix 50.5x Alarm
, P3 Brake Controller, Swamps Injectors, PHP Tunes
crowz is offline
post #4 of 8 (permalink) Old 11-19-2009, 11:17 AM
That factory tranny should not be trusted! A couple years ago while towing in the mountains my aftermarket tranny gauge was showing that it was overheating. When I got into Yellowstone at camp I was about 4qts low on fluid from it overheating and burping it out. ( the factory gauge said normal the whole time ) So having the aftermarket gauge in my opinion saved my tranny.
shovelrog is offline
post #5 of 8 (permalink) Old 11-19-2009, 05:21 PM Thread Starter
edge186's Avatar
oh i see.
yeah he told me that once the gauge got up to a certain point it would never move.
Edge CTS Insight
AFE Stage II Intake
BTS Valve Body
Foil Delete
AIH Delete
CCV Mod
edge186 is offline
post #6 of 8 (permalink) Old 11-19-2009, 07:09 PM
aklim's Avatar
I'm glad I don't have it. About as useful as the oil pressure gauge that reads "Normal" no matter what as long as the pressure is above 5 psi
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U front and A Rear.
aklim is offline
post #7 of 8 (permalink) Old 11-20-2009, 04:33 PM
casper7.3's Avatar
on my buddies 02 it could be 30 degrees out side and after about 10 minuets of IDLE time the trans temp would go up to its normal point and stop..kinda weird
LUKE
2002 CCLB AUT0 4X4
S&B, DI/PRICOL GAUGES, CCV, ZOODAD, TS CHIP-MATT AT GEARHEAD,
38R, ADRENALINE, SWAMP'S IDM, 4" T/B MBRP
05 CONVERSION, 4 INCH LIFT, 325/65-18 FIERCE ATTITUDE M/T
WILSON 5000 GALAXY DX66
casper7.3 is offline
post #8 of 8 (permalink) Old 11-20-2009, 06:55 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
The stock gauge moves from cold to normal at 50F. At 230F it moves to yellow. I think it's about 260F it moves to red.
Mark Kovalsky is offline
