transmission or the torque converter?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 11-18-2009, 06:08 PM Thread Starter
SiC sEnSe's Avatar
Question transmission or the torque converter??
I know this a new b question but how to you know when the transmission or the torque converter is going out?? Cause at take off right as you let go of the brake and hit the gas my truck does like a bump then go but only at take off when shifting to other gears its nice and smooth and no hesitation so before i got buy anything like this suncoast heavy duty master rebuild kit( )Sun Coast Converters Diesel Transmissions, Fort Walton Beach FL for 500 bucks is going to fix my problem or would a new Torque converter fix it and im doing this because i think my trans need to be freshened up its got 269000 and i dont know how the previous owner treated the trans
00 f250 7.3 powerstroke 4x4:: RBP 4" TB with a RBP 4 to 5" tip::TS Chip with PHP tunes
SiC sEnSe is offline
post #2 of 5 (permalink) Old 11-18-2009, 11:09 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: transmission or the torque converter??
Your problem is most likely the slip yoke on the driveshaft. The splines get dry and stick. Ford sells a teflon grease that works great to fix this.
Mark Kovalsky is offline
post #3 of 5 (permalink) Old 11-19-2009, 01:40 AM Thread Starter
SiC sEnSe's Avatar
so would this be something i can do myself?? and would that kit from suncoast to freshen up the tranny
post #4 of 5 (permalink) Old 11-19-2009, 10:26 AM
Yes. Take the driveshaft out and grease the slip yoke.
Make sure the parking brake is on AND the wheels are chocked before removing the driveshaft.
There is a thread on another forum where someone removed the driveshaft with his truck on an incline and didn't have the wheels chocked. He broke two bones.
post #5 of 5 (permalink) Old 11-26-2009, 04:51 PM
mines was doing the same, it stopped mine
2002 F250 CC 4x4
Tommy69Z28 is offline
