Slipping Trans?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 11-12-2009, 10:34 AM Thread Starter
Thomas7.3psd's Avatar
Question Slipping Trans??
My question is, my truck in sig seams like all the power is not making it to the ground, it just seams like it used to feal stronger. It has been a long time since i felt what a weak or slipping tranny feals like so i need some suggestions if it sounds weak or if its normal. I used to have another custom ts chip that when it shifted from 1st to 2nd it slammed into gear and i ran it like that for probably 4 months until i got my chip reburned.Then 1st to second shifted fine but now when it shift 1st to 2nd it will grab then a split second later it will grab again kinda like its slipping but like i said i havnt dealt with a bad tranny in about 7 years so i need some insight
02 F250 cc sb Lariet 4x4.
BTS Transmission installed/tuned by TSD
Autometer Ultralite II Trans,Pyro,Boost.
MBRP 4'' Cool Duals turboback with 5'' tips.
DIY tractionbars with Procomp mounts.
6637/zoodad intake,Drilled/slotted Rotors.
Thomas7.3psd is offline
post #2 of 17 (permalink) Old 11-12-2009, 12:43 PM Thread Starter
Re: Slipping Trans??
Bump! just read that one of the weak points of the 4r100 is the torque converter..does anyone know anything about this? could this be the power loss i feal? Thanks
post #3 of 17 (permalink) Old 11-12-2009, 12:52 PM
Snake Oil Salesman
mattr66's Avatar
I'd put money on the torque converter.... at WOT if it hits second, locks up the converter then unlocks the converter it is the converter.
Matt Robinson
Gearhead Automotive Performance
Originally Posted by PSDPlayer View Post
If you have nozzles that were Extrude honed over and over and over again. It will look like a porn stars ass.hole where the pintle is supposed to seal.
mattr66 is offline
post #4 of 17 (permalink) Old 11-12-2009, 01:07 PM Thread Starter
Is that when the TC normaly locks..going into second?
post #5 of 17 (permalink) Old 11-12-2009, 01:13 PM
woodduck97's Avatar
Now I got a question for ya here matt I got a new Daaco triple disk and it it does it some times. My trans isnt weak but I dont know what causes the problem for it to unlock then relock at WOT.
1997 Ford F-250 Sleeper Edition
woodduck97 is offline
post #6 of 17 (permalink) Old 11-12-2009, 01:17 PM Thread Starter
how can you tell that the trans isnt weak and its just the TC...just good ole seat of pants or is there a way?
post #7 of 17 (permalink) Old 11-12-2009, 02:14 PM
Snake Oil Salesman
mattr66's Avatar
Your programming locks immidiately at WOT as soon as it hits second. I lock them in second to save the clutch in the torque converter because it is much less strain on it in 2nd gear than locking for the first time in 3rd gear. The stock clutch can only take it for so long at power levels above stock.
When it acts up does it try to relock at some point if you stay in it or does it simply stay slipping the rest of the time?
I have a good used precision converter in the garage if you are interested.
Matt Robinson
mattr66 is offline
post #8 of 17 (permalink) Old 11-12-2009, 02:22 PM Thread Starter
Its hard for me to describe it, i dont know alot about it but i think it locks, it just feals like it hesitates for a split second before it locks but it may be slipping for all i know but it doesnt over rev or anything..how much for the used TC?
post #9 of 17 (permalink) Old 11-12-2009, 02:53 PM
Snake Oil Salesman
mattr66's Avatar
It is guaranteed good and has about 7k on it and I'll let it go for 700 dollars.
Matt Robinson
mattr66 is offline
post #10 of 17 (permalink) Old 11-12-2009, 03:48 PM
woodduck97's Avatar
Yea mine locks for a split second then unlocks trys to lock and relocks but I am not going to be racing it so I am not to worried bout it and I usally dont ever run it wide open. But when something breaks in it I am going to a BTS.
