e40d help NEEDED! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 11-09-2009, 10:15 AM Thread Starter
indirectly strokin
93 Indirect Injected's Avatar
Question e40d help NEEDED!
alright guys need some help here, i have a '93 f250 with the 7.3 id and the lovely e40d tranny yesterday i finally got it running after several months of down time and the "OD" began blinking like it did prior to rebuilding the trans(before it was parked, theres like 800 miles on the rebuild), i pulled the dipstick and levels were fine so im deff in some need of help here, auto trannys aren't exactly my strong area of work
93 Indirect Injected is offline
post #2 of 10 (permalink) Old 11-09-2009, 01:10 PM
OBS junkie
Cat_Rebel's Avatar
Re: e40d help NEEDED!
Unhook both batts for a couple mins to reset the codes. Then hook them back up & take it for a drive & see if you can pickup when the light comes on. Mine would come on going up a hill or getting into it to speed up. Going up a hill I could watch the tach bounce about 50rpm then the light would come on. My converter was done, replaced the converter & so far so good.
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #3 of 10 (permalink) Old 11-09-2009, 03:25 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
I wouldn't do that. I would read the codes first. Then you'll have a good starting place to find out what's wrong.
Mark Kovalsky is offline
post #4 of 10 (permalink) Old 11-09-2009, 09:24 PM Thread Starter
indirectly strokin
oh the code reading, where would be a go place to get the code read at being my truck is the "OBD1" and places like advance auto or autozone can not read them? thanks for the help and advice already guys
post #5 of 10 (permalink) Old 11-09-2009, 10:07 PM
OBS junkie
Cat_Rebel's Avatar
Have to go to the dealer or trans shop. I never got around to getting codes pulled on mine since I couldn't track down anyone local I did it the hard way. If you can count the times it blinks it will tell you the code. PM RacerX he knows how to do it on the older trucks.
RIP Will Iott
post #6 of 10 (permalink) Old 11-10-2009, 12:12 AM
You can buy an OBDI code reader for under $30 at most parts stores, Wally World, Kmart, etc.
post #7 of 10 (permalink) Old 11-10-2009, 01:59 AM
The Fireman's Avatar
Get em read, could be somethin like a speed sensor.
Bryan
97 F250 SC LB 4x4 Auto 368,000 miles, AD's, 3in down pipe, Straight Pipe,EBPV deleted, DIY Intake, Racer X converter and valve body, Beans tunes
The Fireman is offline
post #8 of 10 (permalink) Old 11-10-2009, 09:44 PM Thread Starter
indirectly strokin
ok heres exactly wat its doing, it will move around fine and everything until you accelerate it past first gear(which it wont shift until a higher rpm, way higher than normal) and then the OD light comes on and it blinks in a constant on-off-on-off, no pattern what so ever, then in reverse it wants to stall out like the torque is tryin to lock up(and thats not even moving at all)
i guess im goin to just have the code read, thats the only thing i can figure
post #9 of 10 (permalink) Old 11-10-2009, 09:47 PM
OBS junkie
Cat_Rebel's Avatar
The E4OD has 4 gears, the converter lockup feels like a gear by itself.
RIP Will Iott
post #10 of 10 (permalink) Old 11-10-2009, 11:06 PM Thread Starter
indirectly strokin
ya lost me there, it locking up feels as if you would be slipping out a clutch while holding the brake, it is alway pulling the rpms down as it "locks up"
