4R100 took a doody. Maybe? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 11-09-2009, 12:22 AM Thread Starter
NVJAY775's Avatar
Hey guys. My son has my old 99 4x4 7.3. 150,000 mi.
K/N filter in stock box
315 tires
373 gears
DP Tuner
muffler / cat delete.
Yesterday night it made the 1/2 shift like normal, then the 2/3 shift was real hard and then nothing in any gear?
Any thoughts on what happened?
Thanks
Jay
Silver 00 4x4 ex cab lb
305 70 16's
DIY Tymar
5" stack
Modded H2E from ctperformanceinc.com
180cc AA's
DP Tuner F5
Full Jimmy Converse trans / converter
6.0 trans cooler
NVJAY775 is offline
post #2 of 5 (permalink) Old 11-09-2009, 12:52 AM
Metal - It kicks your ass
Re: 4R100 took a doody. Maybe?
Sounds like what i just got done dealing with. May be the beginning stages. I had a TC ballooning, clutch packs slipping, sprags (not sure what those are) goin out.
I ended up having to get a full rebuild. Im no trans expert but i had somewhat similar problems. First off make sure your fluid is full and not burnt. If thats not it you may want to scan it for codes. That should give you an idea of whats goin on.
Modded L99
dirtboy25 is offline
post #3 of 5 (permalink) Old 11-09-2009, 03:00 AM Thread Starter
NVJAY775's Avatar
I'll see if I can get my buddie to scan it. The fluid is clean and smells normal. Thanks! I'll post up as things move along. Might be a good time for a new trans. But he's trying to save for school, in between breaking the truck. It's a kid thing. I'm not paying a dime this time around. Dad's a dick. What can I say....
305 70 16's
DIY Tymar
5" stack
180cc AA's
DP Tuner F5
6.0 trans cooler
NVJAY775 is offline
post #4 of 5 (permalink) Old 11-10-2009, 02:04 AM
The Fireman's Avatar
Sounds like you might have broke one of the shafts, one of the experts will tune in before long
Bryan
97 F250 SC LB 4x4 Auto 368,000 miles, AD's, 3in down pipe, Straight Pipe,EBPV deleted, DIY Intake, Racer X converter and valve body, Beans tunes
The Fireman is offline
post #5 of 5 (permalink) Old 11-10-2009, 02:26 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Something mechanical failed. There are several things that can break and do this.
Mark Kovalsky is offline
