4r100 slips going into OD - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 08-09-2015, 09:21 PM Thread Starter
dkrajcovic
just got my trans rebuilt & now when it shifts into OD it will rev up a little bit & then go into OD
once in OD seems to hold just fine
it seems to be worse in my 120 race tune (PHP tuner)
did not slip & shift funny before rebuild ( got trans rebuilt b/c I blow a trans line & did not know until it started to slip )
no codes or flashing lights
trans builder seems to think it is the pump has a crack or the trans case has a crack
truck is a 00 f350 4x4 drw
Thanks
2000 f350 drw, grages, 4" down pipe, 4" dp back , FRx, 6637 filter, ccv kit, PHP tuner
dkrajcovic is offline
post #2 of 13 (permalink) Old 08-11-2015, 12:28 PM Thread Starter
dkrajcovic
Re: 4r100 slips going into OD
anyone got a clue what mite be going on
post #3 of 13 (permalink) Old 08-11-2015, 04:20 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
It might be the tuner.
Mark
Mark Kovalsky is offline
post #4 of 13 (permalink) Old 08-11-2015, 08:49 PM Thread Starter
dkrajcovic
How can I tell ??
If I put it to the stock setting on the tuner it still
Does it just not as bad
Or do I just need to pull the tuner off
It did not do it before the rebuild ??? No any tune
post #5 of 13 (permalink) Old 08-13-2015, 02:01 AM
Take the tuner off the truck.
Mark
post #6 of 13 (permalink) Old 08-13-2015, 02:31 AM Thread Starter
dkrajcovic
Took it off today & it drove good
How did the PHP tuner make it slip
I do not understand it was fine before the trans was rebuilt
@markkovalsky
post #7 of 13 (permalink) Old 08-14-2015, 12:10 PM
The transmission is 100% computer controlled. The tuner modifies the computer. If they computer isn't controlling the trans correctly it can slip.
Mark
post #8 of 13 (permalink) Old 08-14-2015, 02:50 PM Thread Starter
dkrajcovic
THANKS @markkovalsky
now for the next problem now it has a long shift into 2nd gear (shifts around 2900 to 3000 rpms) & some times it will not shift into 2nd without letting off the fuel pedal
hooked up scanner & it is commanding it the shift but will not shift
has new solenoid pack ,shift kit & full rebuild, new pump, billet converter, 6.0 cooler,
trans guy is saying that it is the computer ??? I do not think it is b/c the scanner is telling it to shift but it does not shift seems to me that something is sticking or the solenoid pack is bad
thanks for all the help mark I was hopping you would help
post #9 of 13 (permalink) Old 08-14-2015, 10:34 PM
If the computer is telling it to shift and it isn't shifting the problem is inside the transmission, not the computer.
Mark
post #10 of 13 (permalink) Old 08-15-2015, 03:06 AM Thread Starter
dkrajcovic
Thanks
Do you know what may be the problem
