E4OD Question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 08-07-2015, 11:39 AM Thread Starter
E4OD Question
Hello, I have here a 1989 F-350 7.3 IDI without a turbo, 4x4 E4OD D60F and 10.25 R with 4.10 gears.
When the engine isn't warmed up, it makes 1800 rev's @ 25 Miles per hour,
I didn't feel that is normal, can somebody tell me something about that?
The truck has only 8000 Miles on it.
Oh, what is Transmission Final Gear Ratio?
and what's that for this truck?
Thanks a lot.
Bart
1989 F-350
bart f-350 is offline
post #2 of 2 (permalink) Old 08-07-2015, 02:15 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: E4OD Question
The E4OD has four ratios. 2.71:1, 1.54:1, 1:1, and 0.71:1. Final drive ratio usually refers to the axle ratio, not a transmission ratio.
Yours doesn't seem to be shifting when it should. There is a sensor on the engine injection pump that probably needs to be replaced or at least adjusted. I don't have the procedure.
Mark
ďThe good thing about science is that it's true whether or not you believe in it.Ē ― Neil deGrasse Tyson
Mark Kovalsky is offline
