trans temp gauge installed, trans temp seems low??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 11-04-2009, 04:21 PM Thread Starter
DIESEL DAN's Avatar
installed stewart warner trans temp gauge in a 99' super duty that has the
4r100. i drove it around, and it never got above 140*. came home after 10 mile trip, felt pan, it was a little warm.
are these trannys cooler running?
please let me know.
pm me any comments.
thanks
dan
DIESEL DAN is offline
post #2 of 13 (permalink) Old 11-04-2009, 04:23 PM
Re: trans temp gauge installed, trans temp seems low???
What is the temp outside? sounds normal to me
F-350 is offline
post #3 of 13 (permalink) Old 11-04-2009, 04:40 PM
mine usally runs around 150*
02 f250
countryboyrob is offline
post #4 of 13 (permalink) Old 11-04-2009, 04:42 PM
Lovin the Tuna
RedSmokey's Avatar
sounds about normal. This isnt towing, correct?
2001 F250
2000 F250
RedSmokey is offline
post #5 of 13 (permalink) Old 11-04-2009, 11:25 PM
Lurker...
Fever's Avatar
Mine runs 70 to 80 degrees warmer than the ambient temp when not towing....around 100 degrees over ambient when towing my camper...
2003 F-350 Super Duty
Fever is offline
post #6 of 13 (permalink) Old 11-05-2009, 05:07 AM Thread Starter
DIESEL DAN's Avatar
i think it runs lower than 140*. my gauge dosen't go any lower. i put the temp sensor in the 1/8 pipe in the driverside of the trans. should i put in the side of the pan??
post #7 of 13 (permalink) Old 11-05-2009, 11:29 AM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
No, you shouldn't move it to the pan. You have the sensor in the best place already.
When not heavily loaded the trans should be about 60F above ambient temperature after about 10 miles of city driving.
Mark Kovalsky is offline
post #8 of 13 (permalink) Old 11-06-2009, 01:22 AM
tbolt's Avatar
Mine while freeway cruising unloaded in 100+ degrees runs 165-175. I think you are pretty accurate. Where are you?
Glen
early99 f350 cc, lb, 2wd, drw, A pillar autometer guages, CTS monitor, AIS intake, 4" turbo back cat delete diamondeye exhaust, dptuner, pmt1, jw vb, Swamps ab inj, Adrenaline oil, Coolingmist, 180*T, Trucool cooler, spin on trans filter, Firestone air bags, 2" frt leveling kit, now chased by a 34' toyhauler
tbolt is offline
post #9 of 13 (permalink) Old 11-06-2009, 04:06 AM Thread Starter
DIESEL DAN's Avatar
wisconsin, weather here has been somewhat good (40-55 degrees)
post #10 of 13 (permalink) Old 11-06-2009, 05:39 AM
When I first put mine in I didn't think it was working. Just took a long time to heat up. Felt pretty dumb after crawling around under my truck on the side of the road to have it move like half a mile down the road.
bigjake0524 is offline
