Drive train Slack - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 11-02-2009, 03:02 PM Thread Starter
Angry Drive train Slack
Well i have a late 99 7.3 4x4 with the zf6 and it seems like there is alot of play in the drive train, i dont know weather it is in the transfer case or where, but it annoys me because it makes it a rough ride when you let off the fuel pedal and then give it some fuel, anyone have any ideas or suggestions?
99_F250_SD is offline
post #2 of 11 (permalink) Old 11-02-2009, 03:18 PM
3YLSYKR's Avatar
Re: Drive train Slack
I've had this before. Happens sometime but not all the times. I'm not sure if it's the drive line, rear end, trans, transfer case ect..
8" Lift
38" Toyo MT's
DIY Traction Bars
Zoodad-AIH Delete-Foil Delete
Adjust. Wastegate
ISSIPRO Performax Gauges
4" TB Magnaflow Exhaust w/ 5" tip
AFE stage 2 PG 7 W/Pre-Filter
Superchips Prgmr 150HP/225TQ
Oil X-over Line
Smoked Lights w/LEDs & HIDs
DIY 3 stage Water/Meth
CCV
6.0 IC
Transgo Shift Kit
Derale Trans. Frame Rail Cooler
3YLSYKR is offline
post #3 of 11 (permalink) Old 11-02-2009, 06:08 PM Thread Starter
well i need to know where to start because its bugging the hell out of me
post #4 of 11 (permalink) Old 11-02-2009, 06:26 PM
Grease the splines on the rear drive shaft and see if it goes away before you go on a wild goose chase.
Blue Water Runner is offline
post #5 of 11 (permalink) Old 11-02-2009, 08:23 PM
3YLSYKR's Avatar
I did this over the weekend and it seemed to help a little.
8" Lift
38" Toyo MT's
DIY Traction Bars
Adjust. Wastegate
Oil X-over Line
CCV
6.0 IC
Transgo Shift Kit
3YLSYKR is offline
post #6 of 11 (permalink) Old 11-02-2009, 09:10 PM
i would also check the rear axle to hub bolts . I had that problem.
1999 F350 6SPD 4x4 LARIAT Tymar, DP-F5, ITP Reg Return, 4" Exhaust **SOLD**
2002 F350 REG CAB DRW 2WD Tymar, PHP, 5" stack, DJM drop hangers and shackles, Hellwig sway bars, Nathan K5LA, Full Power '08 Mirrors...**SOLD**
DIRTBIKEZ is offline
post #7 of 11 (permalink) Old 11-03-2009, 01:24 PM
3YLSYKR's Avatar
Good thinking DIRTBIKEZ
8" Lift
38" Toyo MT's
DIY Traction Bars
Adjust. Wastegate
Oil X-over Line
CCV
6.0 IC
Transgo Shift Kit
3YLSYKR is offline
post #8 of 11 (permalink) Old 11-04-2009, 01:28 AM Thread Starter
could the driveshaft support bearing do this also?
post #9 of 11 (permalink) Old 11-04-2009, 01:56 AM
oil burner
tughill283's Avatar
my truck has tons of driveline slack,i just live with it.it can be from excessive gearlash in the rear diff.try to turn the driveshaft w the truck parked in nuetral to find rear diff slack. then try to turn it with the truck off the ground in gear,that will tell yuo if its rear diff or transfer case/transmission.
96 f250, ZF5,160cc,
300k miles
96 f350 plow truck
tughill283 is offline
post #10 of 11 (permalink) Old 02-05-2010, 12:42 AM
PSDfan99's Avatar
I just saw this old thread. My truck has excessive slack in the drive-line when I get on and off the gas pedal, and when I'm in OD and the TCC is locked you can really hear and feel it when you get on and off the gas. It's a very distinctive "clunk".
I took the rear driveshaft off the truck and test drove it to see if I could confirm that it was indeed a driveshaft/ rear end problem, but the clunk/ slack is still there exactly as it was before with the driveshaft in.
I think I've narrowed it down to the transfer case, because I highly doubt its a transmission problem.
What do you guys think?
Early 99 F-350
4" lift on 33's. Daily Driver/ Plow truck.
Swamp's Gen3, 300/200's, Tuning, 76mm Sledgehammer. BTS. Fuel system, ARP's, P-Rods, 910's, and a few other things. Stock Block.
SOLD
New truck:
2009 F-350, 5.4L, 4" lift on 35's
PSDfan99 is offline
