6.0 Cooler into a '02 7.3? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 11-01-2009, 01:55 PM Thread Starter
I am considering a 6.0 cooler into my 7.3. What specific mods will I need to make or will this bolt right up? Also, any thoughts on a bone yard search for a cooler? Thanks in advance. How complicated is this switchover?
Kevin t is offline
post #2 of 6 (permalink) Old 11-01-2009, 02:09 PM
tank's Avatar
Re: 6.0 Cooler into a '02 7.3?
The cooler bolts right in the same exact spot. The 6.0 cooler lines are 1/2" where stock 7.3 is 3/8". So you will have to get a 3/8"-1/2" brass barb to adapt the differant size lines. It's an easy job to do.
E99 F250 CCSB 6 pos chip Gearhead Auto
Swamps 250/80 hybrids ARP head studs DI pushrods Comp 910s Adrenalin hpop ceramic coated 38r and up pipes complete fuel system + regulated return water/meth full built trans PI converter JW vb afe2 intake and afe bladerunner 3" intakes 4" tb exhaust 6.0 tc pmt 1 boost egt + scangauge
tank is offline
post #3 of 6 (permalink) Old 11-01-2009, 05:20 PM Thread Starter
Is $259 a good price?
Kevin t is offline
post #4 of 6 (permalink) Old 11-02-2009, 02:33 AM
I got one out of my local junk yard for $35...
On a side note, it has been around 30 deg. in the morning, and now my trans will not go over 100deg on the temp gauge. is this bad?
Hijack over!!
2001 F-250 4x4 Crew shortbox, Optix gauges, DP F5 60towHighAlt, 80E, 100, 120. WW, ITP Boost Annihilator. DIY 6637 intake.
redmist is offline
post #5 of 6 (permalink) Old 11-02-2009, 02:54 PM
Village Idiot
southmike's Avatar
for a new one yes for an old one keep lookin
southmike is offline
post #6 of 6 (permalink) Old 11-02-2009, 10:14 PM
tank's Avatar
I payed $60 shipped for the 31 row from a wrecking yard.
tank is offline
