E4OD OD light flashing - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 22 (permalink) Old 07-11-2015, 07:34 PM Thread Starter
I need some assistance. I have a 97 psd 4x4, recently I have noticed that the torque converter fails to lock up and I will pull off the road and shut the truck off and restart and the problem goes away. This happens intermittently not everyday. I thought it may be the truck being cold or something like that. My father in law said he never had any issues with the truck and that the trans was rebuilt some time ago by previous owner. Truck had no codes and is shifting fine.
Yesterday I installed a TS 6 pos chip. When I started the truck the OD light was flashing. When I put it in drive the light stops flashing and the OD button works. Truck seems to drive and shifts like before. Could the chip just intensify a previous problem or could the chip be bad? All the positions on the chip work.
I tried to scan for codes but none were stored in the computer.
Could it be a bad tq converter or bad solenoids?
97 F250HD XLT. 4x4 7.3 CCSB, 140,000 miles, 33" tires, 355 limited slip rear axle, 4" turbo back and 6637 Intake, glow shift gauges, PHP 6 position chip.
I don't know what's next.
PSD ADAM is offline
post #2 of 22 (permalink) Old 07-11-2015, 07:59 PM
Administrator
Zmann's Avatar
Re: E4OD OD light flashing
there is a code if the light is flashing but you need a good reader
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #3 of 22 (permalink) Old 07-12-2015, 12:59 AM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Yes it could. Or bad wiring. Or bad sensors, some of them are not even on the transmission. Or an internal trans problem.
There are codes stored. You need a better tool than you have to read them. Without the codes all I can do is list everything and you go buy it all and install them until the problem goes away.
Mark
Mark Kovalsky is offline
post #4 of 22 (permalink) Old 07-12-2015, 03:23 AM Thread Starter
The code is 0708
I checked the connector on the trans and it's connected.
I also noticed when selecting gears, say from reverse to drive the light will flash and the shift into drive is a little more harsh.
PSD ADAM is offline
post #5 of 22 (permalink) Old 07-12-2015, 01:57 PM
That indicates an electrical problem with the Transmission Range Sensor (TRS.) The TRS is located on the driver's side of the transmission. It is the part with the wiring harness attached to it. The problem could be the TRS itself OR the wiring between the TRS and the PCM.
Mark
post #6 of 22 (permalink) Old 07-12-2015, 07:44 PM Thread Starter
Changed the sensor and no change.
Could the TS 6 pos chip effect this at all?
Also in park the truck seems to be idling a little high, around 850 rpm
PSD ADAM is offline
post #7 of 22 (permalink) Old 07-12-2015, 09:52 PM Thread Starter
Update
I pulled my TS chip and problem went away. I'll be calling KT performance tomorrow
PSD ADAM is offline
post #8 of 22 (permalink) Old 07-14-2015, 02:07 AM Thread Starter
Have to send my chip back. KT performance customer service is awesome, Kenny is the man over there.
PSD ADAM is offline
post #9 of 22 (permalink) Old 07-16-2015, 01:17 AM
I recall my TS instructions said the %99 of the problems with chip installs are a failure to properly clean the contacts.
1996 F250 CCSB, 4x4, auto PSD, stainless window vents.
Signature file limitations keep me from sharing more information. Follow this link to find my threads: D60 RSK install, Air vent cleaning, etc.
leojr is offline
post #10 of 22 (permalink) Old 07-16-2015, 04:03 AM Thread Starter
I'm sure most are however my chip was programmed for an E350 Canada built van.
So I don't think I'm in that 99%.
PSD ADAM is offline
