2002 excursion 4r100 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 07-04-2015, 05:03 PM Thread Starter
236k miles
it just started to do this , when you put it in reverse it acts like its half way in park like its bound up or the brakes are on you have to mash the gas to get it to back up and it will go back but with quite a bit of resistance, other thing I notice is when put in neutral it has some forward movement to it kinda like its half way between neutral and drive, but so far all forward drive is fine. any ideas????
ccobra70 is offline
post #2 of 3 (permalink) Old 07-04-2015, 09:12 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: 2002 excursion 4r100
Not just an idea, I know what's wrong. Your forward clutch has failed and won't fully release. Unfortunately you'll need to either replace or rebuild the trans. This is only going to get worse until it won't reverse at all.
Mark
The good thing about science is that it's true whether or not you believe in it. ― Neil deGrasse Tyson
Mark Kovalsky is offline
post #3 of 3 (permalink) Old 07-04-2015, 10:17 PM Thread Starter
ok that's what I need to know thanks mark
ccobra70 is offline
