E4OD reverse issue - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 07-02-2015, 02:11 AM Thread Starter
<---F350 DRIFTER
drwoodchopper's Avatar
E4OD reverse issue
So I just put in a rebuilt transmission tonight after I stripped the splines off the torque converter. I get the fluid in and it feels like it slips when you push on the accelerator in reverse, the engine speeds up and you can feel it "catch" it will repeat this any time it is brought back to idle and at minimum to maximum fluid levels. It seems to fe fine in drive and goes through the gears as it should.
Any thoughts before I drive it to the shop tomorrow?
97
PSD. CC 4X4 195K, IDM mod, 6 Leaker IC, DP Tuner 6pos chip, WOP QSSB Turbo, kit by Carson Stauffer. Swamps 175/146's sticks, CNG kit 35mpg's on the diesel, E-fuel, Adrenaline and converted to a ZF5. RSK rolling on 35's. 4" straight pipe. 2011 f350 ccsb leveled on 35's, I can neither confirm nor deny that it is tuned and deleted!
drwoodchopper is offline
post #2 of 4 (permalink) Old 07-02-2015, 11:28 AM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: E4OD reverse issue
If it has enough fluid there is something wrong inside the reverse clutch. Probably a bad seal.
Mark
Mark Kovalsky is offline
post #3 of 4 (permalink) Old 07-02-2015, 01:07 PM Thread Starter
<---F350 DRIFTER
Thanks Mark. Which seal? I don't think it is a fluid issue just because it seemed to be the same even when I tried it a bit "over full" and everywhere in between last night.
97
post #4 of 4 (permalink) Old 07-02-2015, 05:15 PM Thread Starter
<---F350 DRIFTER
So the shop guy thinks he forgot to torque the 3 bolts on that little plate by the valve body and solenoid body can't remember what it is called so the fluid is blowing by. Hopefully that is all it is.
97
