Trans pump seal? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 10-28-2009, 01:16 AM Thread Starter
Member
Tizzo's Avatar
Trans pump seal?
got a friend that will sell his 95 F250 4x4 ECLL to me for 1800. HE said the pump seal is all that is bad. he was driving and was stopped because the trans pumped all the fluid out of the front of trans... he had a couple of shops say thats all it is.... does that make since? all i want is another PSD, and i would want to do least work on it... so does it sound like thats all i would have to do to it?
If your gonna be Dumb, You gotta be TOUGH
Tizzo is offline
post #2 of 4 (permalink) Old 10-28-2009, 01:25 AM
F250 Black Cloud Edition
Gotti2k7's Avatar
Re: Trans pump seal?
Check the flexplate for cracks. The converter could be wobbling in there and wear out the bushing, then it will leak too. Which leads into ruining the front pump.
02 F250. Turbonetics, SRP1, Tim from P.I.S built Hybrids, Built Trans, Afe Stage 2, HPX line. Tuned by Jonathan from Beans, 4 inch exhaust, with the muffler. Triple Phantom 2 gauges. Forged Rods and with another block. 500hp.
Gotti2k7 is offline
post #3 of 4 (permalink) Old 10-29-2009, 12:08 AM Thread Starter
Member
Tizzo's Avatar
makes since, thanks Gotti .so my question still is.... can i only replace or fix the seal on front pump.
thanks
Tizzo is offline
post #4 of 4 (permalink) Old 10-29-2009, 12:24 AM
Crazy Talk
powerstrokenstang's Avatar
Send a message via AIM to powerstrokenstang
yes.
1996 F-250 ex-cab -D60- Motor,fire hoses-Nate,Tuning,Cam-Matt R,P-rods,dummy plugs-Wipe Out,Huffer-Engineered diesel,Carson,Gen3,Idm-Swamps,Rods,studs,fire rings-WOP,Clutch-Valair
455/400's in,S475 T-6 mounted
'84 f-350 2wd, 6.9l, 4spd, drw, flatbed. For Sale
powerstrokenstang is offline
