E4OD case Id help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 06-20-2015, 02:27 AM Thread Starter
E4OD case Id help
Transmission is supposedly from a '97, pump is f5, valve body is f6, but when I went to put check balls in I noticed the case looks like a much older model. I am trying to attach a picture in case anyone is familiar.
Tinscout is offline
post #2 of 3 (permalink) Old 06-20-2015, 07:13 PM
Re: E4OD case Id help
Was this a trans that u pulled apart? Did it work? Or is this a frankentranny that your trying to make work
Wrench4alivin is offline
post #3 of 3 (permalink) Old 06-20-2015, 09:22 PM Thread Starter
I don't have all of the history on this truck other than I was told that the transmission had been repaired or replaced at least twice before. I was also told that it was never right after the last repair. I was able to find some information from atsg on parts identification and I think all is well. The drawing I was initially using for check ball placement had different worm tracks.
Tinscout is offline
