4r100 Problems Mark Kovalsky? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 06-17-2015, 12:43 PM Thread Starter
Just put my old 7.3 on the road and the tranny seems to be a little screwy. The tranny seems like it doesnt know when it should shift out of OD going up a hill I had to manually shut off the OD or I wasnt going up the hill it lugged the thing right down. I have had the batteries disconnected and I remember reading some where that disconnecting the batts erases the shift points and you start from scratch again. Could that be the case or something more extensive. FML
Any help is appreciated.
powerstrokeboy2000 is offline
post #2 of 14 (permalink) Old 06-18-2015, 01:31 AM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: 4r100 Problems Mark Kovalsky?
It's something else because disconnecting the batteries does NOT erase the shift points. In fact, it doesn't do anything at all to the transmission software.
Are there any codes stored? Does the OD OFF light work? Has it flashed?
Mark
Mark Kovalsky is offline
post #3 of 14 (permalink) Old 06-18-2015, 03:05 AM Thread Starter
Thank you for your prompt response. To answer your questions the light does work it flashed in the past due to a bad vss, once replaced the problem was corrected. I ran a code reader through it a while back my results were the following, PO541, P1670, PO478, P1298, PO380, PO603, F1784, PO500. I haven't ran the scanner since.
Thank you very much
Best Regards,
Brandon
post #4 of 14 (permalink) Old 06-18-2015, 09:51 AM
richyrich's Avatar
Clear the codes and drive it again to see what code(s) show back up from the existing problem
2002
f-250 7.3L powerstroke superduty xlt sc sb 4x4 offroad, pure turbos 360 turbo rebuild kit,
mile marker 449 s/s hub locks, php phoenix 6 position chip, diy 6637 intake, 140k and rollin strong
richyrich is offline
post #5 of 14 (permalink) Old 06-18-2015, 11:38 AM Thread Starter
I will borrow a scanner and report back. Thank you for the advice.
post #6 of 14 (permalink) Old 06-20-2015, 11:44 AM Thread Starter
I scanned it came back with all the codes above except for the po500 for the vss. Also the truck shifts hard for. 1-2 and 2-3 the shifts vary between rough and smooth.
post #7 of 14 (permalink) Old 06-20-2015, 11:59 AM
richyrich's Avatar
Did you scan it then clear the codes drive it again and scan again
2002
post #8 of 14 (permalink) Old 06-20-2015, 12:21 PM
richyrich's Avatar
Also the p1670 is a communication error between the pcm and idm. That could be giving you harsh shifts. The p1298 is a idm failure code. P1784 is an internal trans mechanical failure in first and reverse. That is where I would start first. Google is an incredible entity. Definitely check your fuel pressure. That could be why its being lugged down going up hills.
2002
post #9 of 14 (permalink) Old 06-20-2015, 12:38 PM
I recommend fixing the engine problems before starting on the transmission problems. Once the engine is fixed I think you'll find you don't have a transmission problem any longer.
Mark
post #10 of 14 (permalink) Old 06-20-2015, 01:02 PM
richyrich's Avatar
Smile Re: 4r100 Problems Mark Kovalsky?
That is the same as my thoughts. The engine problems are cutting fuel and the trans is over or under compensating for the poor engine performance. If my thought process is correct?
2002
