Another trans temp gauge question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 10-23-2009, 11:02 PM Thread Starter
Question Another trans temp gauge question
I tried the search, but could not find anything on a machanical gauge install. I only found the electric version, or does the machanical bulb fit into the same spot?
Nitrousjunkie347 is offline
post #2 of 2 (permalink) Old 10-23-2009, 11:28 PM
Re: Another trans temp gauge question
The port on the drivers side of trans is 1/8 npt. I would guess what you need is bigger. You could probably use some adapters or weld a bung in the pan.
03 E-350 7.3, forged rods, exhaust ported heads, comp 910's, 38R/47, 4.10LS, stealth twin pumps, 300cc hybrids from Swamps, h-11's, racerx trans and TC, Swamps tunes, water...
rpm-inc is offline
