billet input yes or no - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 10-23-2009, 01:31 AM Thread Starter
alright had my tranny built a while back with everything in the suncoast catalog except the billet shafts. the tranny has to come back out to fix a leaking front seal which my tranny guy will cover under warranty i asked him about a billet input he told me he usally sees stock ones break at 500 hp give or take a little he said if i buy one he wouldnt charge any labor to install so should i get one or not its only 235 bucks i plan on 500 hp to the tires
99.5 F-250 X-CAB SHORTBED 4X4
Dyno proven tuning
suncoast tranny
P.I.S 238CC/200% hybrids
irate s471 turbo
Fuel system
stealth srp1 hpop
arp studs
comp 910s
CUMMINS_KILLA99 is offline
post #2 of 19 (permalink) Old 10-23-2009, 01:37 AM
OBNOXIOUS MOTORSPORTS
alterdst8's Avatar
Send a message via Yahoo to alterdst8
Re: billet input yes or no
I have the same tranny you have and got the billet input then was told as soon as I had it installed certain bigdogs with 7.3's running mad power with multiple track passes and no breakage yet just use oem cryoed tranny parts save you some major coin, I did my output and planetary drum. You may want to look into that.
02 c/c lariat 4x4 DI studs, Rosewood BIG OIL, 76mm/22cm XXXH2Evil, some fuel, C2 gauges, tru trac F/R 4.30 gears, custom shafts, Stallion TC, Fully built Suncoast, mag hytech pan, 5" pipe, 25k gooseneck hidden hitch , 2 motors, STILL on pmrs in one
Mitch in Mayetta Ks my turbo sponsor
OBNOXIOUS DIESEL built build
alterdst8 is offline
post #3 of 19 (permalink) Old 10-23-2009, 02:47 AM
Village Idiot
southmike's Avatar
I would think the labor ,towing, down time, would cost at least as much
to replace it latter. I would do it. Or at least a better then stock.
southmike is offline
post #4 of 19 (permalink) Old 10-23-2009, 03:33 AM
Subject Matter Expert
PowerstrokeJunkie's Avatar
Dockboy is making some pretty impressive power on his cummins powered ford, low 11's on fuel i recall, and a stock input shaft. I managed to break one and brian sent me a new converter, and a new oem treated shaft, free.
Stock
PowerstrokeJunkie is offline
post #5 of 19 (permalink) Old 10-23-2009, 03:54 AM
ARMY bound
He wouldn't charge you labor to install an input shaft
bbbxcursion is offline
post #6 of 19 (permalink) Old 10-23-2009, 03:58 AM
Village Idiot
southmike's Avatar
iirc dockboy has a bts tranny prob not an oem....but i could be wrong
post #7 of 19 (permalink) Old 10-23-2009, 04:22 AM
HP Junky
Send those stock shafts to Wide Open and have them cryo treated.
RockinJW is offline
post #8 of 19 (permalink) Old 10-23-2009, 11:54 AM Thread Starter
yes sir because the tranny would already be out to fix the front seal. i didnt even bring it up my tranny guy did thats why i think i might get it 235 installed out the door he already sent me the quote suncoast input shaft
Dyno proven tuning
suncoast tranny
irate s471 turbo
Fuel system
stealth srp1 hpop
arp studs
comp 910s
post #9 of 19 (permalink) Old 10-23-2009, 11:55 AM Thread Starter
the only problem with that is i dont have time to wait on all that i can have the billet shaft put in in a day
Dyno proven tuning
suncoast tranny
irate s471 turbo
Fuel system
stealth srp1 hpop
arp studs
comp 910s
post #10 of 19 (permalink) Old 10-23-2009, 11:55 AM
Crazy Talk
powerstrokenstang's Avatar
Send a message via AIM to powerstrokenstang
my billet was not near that much. racerx has a mush better price or at least did when i bought mine. or cryo like jacob said.
1996 F-250 ex-cab -D60- Motor,fire hoses-Nate,Tuning,Cam-Matt R,P-rods,dummy plugs-Wipe Out,Huffer-Engineered diesel,Carson,Gen3,Idm-Swamps,Rods,studs,fire rings-WOP,Clutch-Valair
455/400's in,S475 T-6 mounted
'84 f-350 2wd, 6.9l, 4spd, drw, flatbed. For Sale
powerstrokenstang is offline
