Which tranny fluid? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 10-22-2009, 09:18 PM Thread Starter
Cowboy Up
Which tranny fluid?
I am putting a ZF6 tranny and a NP271 transfer case out of an 01 super duty in my truck and I am not sure what type of tranny fluid they take? Can someone let me know what spec. Ford recommends?
Thanks
'96 F350 CCLB, Dually, 4wd, ZF6, 4.10's, 4" lift, Energy suspension and body bushings, Firestone airbags, 245/70R19.5, 3" DP, 4" MBRP straight pipe, Afe stage 2, TW 6 pos, Autometer gauges, Valair kevlar/ceramic clutch, Stage 1's, Shimmed FPR, Gutted EBPV, Welded pedestal, CCV mod, SD 7.3 intercooler, D66 Turbo, 17* HPOP
INTPSTROKE96 is offline
post #2 of 13 (permalink) Old 10-22-2009, 10:51 PM
peterbilt'in
Rob02F350's Avatar
Re: Which tranny fluid?
all ATF i believe
i know the transfer case is for sure. i just refilled mine with 2 1/4 quarts of mobil 1 fully synthetic. kinda expensive, but i wont worry about it for a while
2002 F350 extended cab XLT, 4x4 auto,194K mi @ 10/25/13, ELF7405, DP F5, ultra light gauges, all kinds of "improvements" Yukon Grizzly locker 6K helper springs, x code fronts. 2 Y2K jetta Tdi. RC2 tuned
Rob02F350 is offline
post #3 of 13 (permalink) Old 10-23-2009, 02:06 PM Thread Starter
Cowboy Up
Does it not have a spec. like Mercon III, IV, or V?
post #4 of 13 (permalink) Old 10-23-2009, 03:26 PM
roughneck0913's Avatar
merc 3 but I'd use merc 5 or full synthetic
roughneck0913 is offline
post #5 of 13 (permalink) Old 10-23-2009, 04:16 PM Thread Starter
Cowboy Up
Why would you do that if they recomend 3?
post #6 of 13 (permalink) Old 10-24-2009, 05:13 AM
PSN Pretender
907DAVE's Avatar
Mercon V
907DAVE is offline
post #7 of 13 (permalink) Old 10-24-2009, 12:29 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
There never was a MERCON 3 or III fluid. Didn't exist. There was DEXRON III/MERCON, which is now an obsolete fluid.
Ford stopped licensing MERCON a couple years ago. They changed MERCON V to be compatible with all transmissions that used MERCON. So now MERCON V is the right fluid for your trans.
Mark Kovalsky is offline
post #8 of 13 (permalink) Old 10-25-2009, 05:43 AM Thread Starter
Cowboy Up
Do I put mercon V in the transfer case to?
post #9 of 13 (permalink) Old 10-25-2009, 07:22 AM
PSN Pretender
907DAVE's Avatar
yes
907DAVE is offline
post #10 of 13 (permalink) Old 10-29-2009, 06:17 PM
Infidel
dexron III in the tranny
Late 99 7.3 F250 cc 4x4
6spd
straight exhaust
6" dr suspension lift
edge evo(i know...)
37" military oz's
190k and climbin
biltfordtufftx is offline
