4r100 shudder - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 06-04-2015, 09:12 PM Thread Starter
4r100 shudder
My transmission has started shuddering? between the 3 to 4 and 4 back to 3 shift. Will shake the truck back and forth under moderate acceleration while towing. Under hard acceleration it's not noticeable. Without the trailer it shifts fine. Trans has 30k miles since full rebuild. Happens in all tunes. Any ideas?
hoschtonhauler is offline
post #2 of 4 (permalink) Old 06-05-2015, 11:26 AM
s10mike's Avatar
Re: 4r100 shudder
Torque convertor
s10mike is offline
post #3 of 4 (permalink) Old 06-05-2015, 05:30 PM Thread Starter
Re: 4r100 shudder
It has a new precision industries stallion convertor. Is there a way to test the convertor while in the truck?
post #4 of 4 (permalink) Old 06-06-2015, 12:52 AM
matthewd11's Avatar
Re: 4r100 shudder
its not the converter. If it was it'd do it all the time on every shift. You either have a problem with the 3-4 shift valve (sticking) or a pressure loss on that clutch set. Shudder is slipping more or less. i'd pull the pan and check things out.
matthewd11 is offline
