can i swap the at from a 01 f250sd in to a 99 f350sd - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 06-01-2015, 02:03 AM Thread Starter
nor
tranny just went out in my e99 f350 no foreword gears just reverse i have a 01 f250 that i rolled can i just swap the trannys with out changing any thing else or do i have to switch out the pcm or some thing else for the tranny to work they are both 4r100 trannys the 01 i had redone about a year prior to rolling it
nor is offline
post #2 of 6 (permalink) Old 06-01-2015, 02:10 AM
whistle tits
ghohouston's Avatar
Re: can i swap the at from a 01 f250sd in to a 99 f350sd
Yes you can, should be a direct swap as long as both trucks are 4x4 or 2x4.
ghohouston is offline
post #3 of 6 (permalink) Old 06-01-2015, 12:12 PM Thread Starter
nor
my main concern is
The early '99 used an on/off torque converter lockup solenoid. The later trans (and for the rest of the 4R100 run) had a Pulse Width Modulated (PWM) solenoid.
nor is offline
post #4 of 6 (permalink) Old 06-01-2015, 02:22 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
That's going to cause some harsh lockups. you need to swap the pump and solenoid bodies to fix this, or live with the harsh lockups.
Mark
Mark Kovalsky is offline
post #5 of 6 (permalink) Old 06-20-2015, 02:36 AM
Early 99 should be pwm
Tinscout is offline
post #6 of 6 (permalink) Old 06-20-2015, 12:43 PM
Early 99 is on/off. It switched to PWM in late 99 and kept PWM for the duration of 4R100 production.
Mark
