New Clutch Time??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 20 (permalink) Old 10-21-2009, 08:50 AM Thread Starter
got another 7.3
smokinford07's Avatar
Send a message via AIM to smokinford07
New Clutch Time???
I've been noticing lately that my truck is getting harder and harder to put in gear after coming to a stop (such as a red light). My wife was driving the other day and it was so difficult I had to reach over and help her get it in gear. Also, when sitting at a stop, in gear with the clutch pedal pressed down, I can give it a little fuel, and it will creep forward. I've also read it could be something with the hydraulics as well, I was just trying to get an idea of what it might be. Also, the pedal has some play in it, the first inch or so I push it down, has no pressure at all. Thank you for your input.
E99 (Red Truck) 4x4, 7.3 4"DP into 5" Flo-Pro exhaust, DIY tymar, 3/8ths fuel line with a holley blue pump,and a PHP Phoenix (stock, 65t, 80dd, 100 performance, 120race, no start) 140v IDM, 285/75/16 Goodyear Duratracs
E99 (Black Truck) 4x4 7.3, 6 speed with a junked motor right now
smokinford07 is offline
post #2 of 20 (permalink) Old 10-21-2009, 08:28 PM
Infidel
Re: New Clutch Time???
sounds like the slave/master cylinder could be the issue
not sure about the obs, but the one on mine(99) is a sealed unit with both slave and master(no bleeding or anything, its all in one, plug and play)
Late 99 7.3 F250 cc 4x4
6spd
straight exhaust
6" dr suspension lift
edge evo(i know...)
37" military oz's
190k and climbin
biltfordtufftx is offline
post #3 of 20 (permalink) Old 10-21-2009, 09:36 PM
Science rulz
Coltaine's Avatar
Send a message via AIM to Coltaine
Never seen a manual Ford picl-up, but there is usually some possibility to adjust the tension of the clutch. Look around in front of the clutch pedal to see if you can adjust it there to get the slack out somehow *shrug*
Coltaine is offline
post #4 of 20 (permalink) Old 10-22-2009, 12:57 AM
Sounds like the master/slave cylinder. My 2001 did the same thing. Hard to get in gear and couldnt get it out of reverse. Clutch would just go to the floor. I also purchased the sealed unit, worked great!
Tipher is offline
post #5 of 20 (permalink) Old 10-22-2009, 06:42 AM Thread Starter
got another 7.3
where might I find one of these? I don't want to have to spend the money for a clutch right now if I don't have to.
post #6 of 20 (permalink) Old 10-22-2009, 03:02 PM
Is this on the OBS in your avitar? If so, look up under the dash at the clutch pedal linkage. There is supposed to be a plastic bushing that centers the linkage pin in the master cylinder eye. That part wears out and then a full stroke of the pedal does not result in a full stroke of the rest of the system. Check that part first.
1995 F350 4x4 CC 5 speed
RDS 160cc injectors
Tymar intake/exhaust
6.0L intercooler
TW chip
SD captains chairs
MagKarl is offline
post #7 of 20 (permalink) Old 10-22-2009, 05:50 PM Thread Starter
got another 7.3
Yes it is in the truck on my avatar, that plastic bushing you are talking about has went out once. I reckon I'll start with that, there is a modification for it using a heim joint, I'll probably do that. Next will be the master/slave cylinder, the clutch and flywheel.
post #8 of 20 (permalink) Old 10-23-2009, 12:42 AM
Custom Trailer Sales
TrailerHauler's Avatar
Sounds exactly like a master/slave cylinder! Check the trans. forum on this sight, there was a thread about upgrading the master slave cylinder to metal rather than the plastic junk. Theres also a mod, for that bushing where the push rod meets the clutch petal.
I believe the OBS guys found that an old branco slave cylinder would fit, and a different slave cylinder.
Here's the thread
1999.5 F350 PSD CC Dually 05' Conversion
Stage I's - Gearhead Tuning - BTS - PCS
F550 rear suspension
1999.5 F350 PSD S/C 6spd Dually
R.I.P. Will Iott - "This ain't no practice run"
TrailerHauler is offline
post #9 of 20 (permalink) Old 10-23-2009, 06:39 AM Thread Starter
got another 7.3
so is this the part i need?
post #10 of 20 (permalink) Old 10-23-2009, 03:03 PM
I would start with the little black snap in bushing with 4 prongs that you see in the eye of the master cylinder pushrod in that picture. I would not mess with the hydraulic system just yet. Those are a real pain to work the air out of.
RDS 160cc injectors
6.0L intercooler
TW chip
SD captains chairs
MagKarl is offline
