tq coverter problem or valve body - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 12-14-2007, 01:32 AM Thread Starter
When my truck is shifting into overdrive sometimes it goes in and out of overdrive 2 or 3 times before it goies into overdrive and stays..If I give it more go pedal it doesnt do it....Usually does this around 38-45mph. Will better tunes and a valve body help me out or am I doomed >>
mindifismoke is offline
post #2 of 4 (permalink) Old 12-14-2007, 10:33 AM
heep70's Avatar
Re: tq coverter problem or valve body
It has something to do with not enough fluid pressure at that RPM to keep it in OD. The fix is a built valve body like John Wood builds.
I am interested in hearing from others on this.
Greg
2000 PSD F250 4X4 Crew, John Wood 4R100, DP Tuner, 4" Diamond eye, Tymar, LIFT, 35" Toyos, Pillar gauges, TC lockup switch, 6.0L cooler, Single core rad, Most of all a Cool Driver, THATS ALL.
heep70 is offline
post #3 of 4 (permalink) Old 12-14-2007, 07:29 PM
Bigfoot is an OBS
cowboy_dan's Avatar
The chip might also have the up and down shift points too close. If it looses speed after the shift due to insufficient power, then it will downshift. You'll want to talk to your programmer about the up AND down shift points.
Go ARMY!
cowboy_dan is offline
post #4 of 4 (permalink) Old 12-15-2007, 05:27 AM
Moderator
Blowby's Avatar
Has this always happened? Tranny fluid at the proper level? How many miles on fluid? Check oil first. Remove your chip and see if the problem goes away.
The shift point can be changed based on the TP and MPH and other parameters (ECU code dependant). They can be perfect at 3.8v and not so perfect at lower positions. The upshift and down shift are controlled by different tables and can have the low TP up/down points too close to each other and the computer is trying to provide instructions to up shift and down shift at the same time. Have your programmer check these for you.
Blowby is offline
