Transfer case - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 10-15-2009, 05:36 PM Thread Starter
Cowboy Up
Transfer case
What is the manual transfer case that goes with a 6 spd. out of a 99-03 7.3? Does it fit any other years or any automatic transmissions?
'96 F350 CCLB, Dually, 4wd, ZF6, 4.10's, 4" lift, Energy suspension and body bushings, Firestone airbags, 245/70R19.5, 3" DP, 4" MBRP straight pipe, Afe stage 2, TW 6 pos, Autometer gauges, Valair kevlar/ceramic clutch, Stage 1's, Shimmed FPR, Gutted EBPV, Welded pedestal, CCV mod, SD 7.3 intercooler, D66 Turbo, 17* HPOP
INTPSTROKE96 is offline
post #2 of 2 (permalink) Old 10-16-2009, 01:46 PM
The Fireman
big_stroker's Avatar
Re: Transfer case
It will fit the zf6 just fine. But you have to change the input shaft on them for them to fit the auto trannys
big_stroker is offline
