what transmission is in this F250? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 04-18-2015, 06:20 PM Thread Starter
year 2004
VIN 1FTNX21P04EA36210
ON THE TRANSMISSION TRANSAXLE CODE ON THE DOOR FRAME IS
AXLE CODE C1
TRANSMISSION B
it is an automatic in the diesel F250
In the owners guide there is no B under the various transmissions listed
Any one now what ratio the C1 is?
lakesidebob is offline
post #2 of 7 (permalink) Old 04-18-2015, 06:54 PM
Administrator
Zmann's Avatar
Re: what transmission is in this F250?
an 04 will be a 6.0
and it will be a 5r1100 torque shift
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #3 of 7 (permalink) Old 04-18-2015, 06:55 PM
Administrator
Zmann's Avatar
the axle will have a tag with the ratio probably a 3.73
EDIT
31 — 3.73 non-limited slip, F-250/Excursion
32 — 4.10 non-limited slip, F-250
41 — 3.73 non-limited slip, F-350
61 — 3.73 non-limited slip, F-350
73 — 4.30 non-limited slip, F-450
75 — 5.38 non-limited slip, F-450
78 — 4.88 non-limited slip, F-450
81 — 3.73 non-limited slip, F-350
88 — 4.88 non-limited slip, F-350
95 — 5.38 non-limited slip, F-550
98 — 4.88 non-limited slip, F-550
C1 — 3.73 limited slip, F-250/Excursion
C2 — 4.10 limited slip, F-250/Excursion
C3 — 4.30 limited slip, F-250/Excursion
D1 — 3.73 limited slip, F-350
D2 — 4.10 limited slip, F-350
D3 — 4.30 limited slip, F-350
E2 — 4.10 limited slip, F-350
E3 — 4.30 limited slip, F-350
EW — 4.10 limited slip, F-350 (ambulance package)
F1 — 3.73 limited slip, F-350
F2 — 4.10 limited slip, F-350
F6 — 4.56 limited slip, F-350
G3 — 4.30 limited slip, F-450
G5 — 5.38 limited slip, F-450
G8 — 4.88 limited slip, F-450
GW — 4.88 non-limited slip, F-450 (wide frame)
K5 — 5.38 limited slip, F-550
K8 — 4.88 limited slip, F-550
KW — 4.88 non-limited slip, F-550 (wide frame)
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #4 of 7 (permalink) Old 04-18-2015, 08:04 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Originally Posted by Zmann View Post
an 04 will be a 6.0
That's one too many 0's. It is a 5R110 TorqShift.
All 2004 diesel F-250s had a 3.73:1 axle ratio.
Mark
Mark Kovalsky is offline
post #5 of 7 (permalink) Old 04-18-2015, 08:41 PM
Administrator
Zmann's Avatar
thanks MK
no special packages or options changed the rear ratio???
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #6 of 7 (permalink) Old 04-18-2015, 11:47 PM
Not from the factory. ALL 2004 F-250 diesels were 3.73:1 ratios. That could always be changed after it left.
Mark
post #7 of 7 (permalink) Old 04-19-2015, 02:43 AM
Administrator
Zmann's Avatar
Interesting that is a factoid I would have never guessed
DTR's Donation page
RIP DTR Ron
Zmann is offline
