is my transmission F'ed again? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 10-06-2009, 06:44 PM Thread Starter
ok this all started after i had my new clutch put in... my tranny will grind when i down shift from 4th to 3rd unless i let it get down to about 25mph then its fine.. but somtimes it will grind going from 2nd to 3rd but not all the time.. does this should like a clutch problem to anyone?
truck is a 2000 with the zf6
GnArKiLL is offline
post #2 of 10 (permalink) Old 10-06-2009, 10:19 PM
Re: is my transmission F'ed again?
sounds like 3rd gear syncro is telling you it's tired.
'01 F250 4x4. 6 spd. GTP38R, Bellowed up pipes, tymar, straight piped, boost & EGT guages.
jopes is offline
post #3 of 10 (permalink) Old 10-07-2009, 02:23 AM
All done now
Arisley's Avatar
That, or there is still air in the clutch line and you are not getting complete clutch release.
Arisley is offline
post #4 of 10 (permalink) Old 10-07-2009, 04:58 AM
Going Crazy
badluck_early99's Avatar
Send a message via MSN to badluck_early99
probably air in the clutch line.... it never leaves
1999 F250 PS 6spd, 37x12.50x17 ProComp Xmud, 06 Grill & Lights. DP tuner, Terminator Hpops, Garrett 42, Casserly B codes, FASS Fuel system by DI, H11's, ITP Reg Return W/Bowl Delete, Sknab 6oh Intercooler, DIY Intake, 4'' Exhaust, Itp OBA, Autometer boost and pyro, , ccv
-Richard-
badluck_early99 is offline
post #5 of 10 (permalink) Old 10-07-2009, 04:58 AM
I would think if there is still air in the line going to the slave cylinder then he would have grinding in all gears, not just 3rd.
To me if it was not releasing all the way, getting in 1st or reverse before the vehicle was moving would be the hardest.
jopes is offline
post #6 of 10 (permalink) Old 10-07-2009, 05:02 AM
Going Crazy
i dunno i had air in mine for a long damn time and it would grind random gears
-Richard-
post #7 of 10 (permalink) Old 10-07-2009, 05:15 AM Thread Starter
yea im going to try bleeding the clutch again tomorrow... i hope that works..
GnArKiLL is offline
post #8 of 10 (permalink) Old 10-11-2009, 04:20 AM
Binder man's Avatar
IMHO its not worth the hassle. I tried on my 7.3 and never could get it bled right ended up taking the slave back and getting fords prebled maser/slave.
Early 99, regular cab, Six Speed, Wildman Tuned, Red wastegate line MIA, muffler MIA, Isspro EGT/Boost, DIY Tymar, EBPV Switch, a slipping South Bend, 2.5" leveling kit, 35x12.5 BFG All-Terrains, 16.5" American Racing wheels SOLD
04, red regular cab, six speed, Edge SOLD
97, silver regular cab 300/200 s300
Binder man is offline
post #9 of 10 (permalink) Old 10-16-2009, 05:07 PM
+1 on the pre-bled assembly. There are several aftermarket ones now. RockAuto has a Dorman and a Rhino-Pac. The Rhino-Pack we just got for my wife's OBS even came with the pedal switch, already loaded on the pushrod. Went in easy peasy.
madpogue is offline
post #10 of 10 (permalink) Old 10-17-2009, 03:58 AM
"Smoke A Lil Smoke"
chappy's Avatar
I would guess syncro also at first. BUT since it started after you did the clutch,I would guess its not bled good enough either.I doubt its a coincidence.
2004 f250 egr delete,studded,fass 95,suncoast convertor,itp RR,Banks intercooler,58v tuned ficm,Powermax turbo,Matts tunes,6in Icon and 35 toyos 20x12 fuels
Early 99 exlb 4wd-SOLD All Shaeffer oil
Will Iott -8/24/84-7/4/10 "We miss you buddy"
chappy is offline
