Trans ? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 20 (permalink) Old 07-16-2007, 10:09 PM Thread Starter
Trans ?
Well, my truck isnt shifting the way it used too with the new added power, it revs up instead of shifting, here is my question.. I have been told that a valve body will help me out quite a bit, I cant afford a full trans build yet, I can afford a tc, vb, and whatever it costs for the front pump. My ts chip is acting up and going back to the stock setting on me(running in 100hp setting then check engine light and back to stock power I go), So I will be getting a new f5 from Jody, So I can have him burn it for whatever route I decide to go. I am getting a valve body at bare minimum. Should I get a 6.0 cooler? I would like to hear what all of you have to say!! Thanks
02 F-350 7.3
08 F-250 6.4
98 3500 12v
Cppr_Busa is offline
post #2 of 20 (permalink) Old 07-16-2007, 10:17 PM
Re: Trans ?
Well, I can give you my personal experience which may or may not help at all.
I replaced my torque converter with the updated "triple disk" one from Ford.
It is NOT the 6.0 converter, but it is supposed to be triple disk, only difference being a thick front cover and lower stall speed for the 6.0 converter. Otherwise the same.
I have a FTVB, don't really like the way it shifts but they are quick and firm, that has saved my trans a lot of slipping.
I also added a magnefine inline trans filter.
If your converter is not dying yet, I would add it BEFORE the coolers, to save it from being polluted if something does happen to the trans.
I truly believe this is why my trans is still together. I'm somewhere in the neighborhood of 375-400 I like to believe, definitely over 350 no matter what, and it's still living.
As far as the cooler, I would NOT do it unless you are having temp problems.
gregrob is offline
post #3 of 20 (permalink) Old 07-17-2007, 12:42 AM
Laces Out
bigrpowr's Avatar
Re: Trans ?
for how cheap a 6.0 cooler is, and with a lifted truck, i would get it if you can find one for cheap or on ebay...i got mine brand new for $125...never gone over 170 on 37's.....worth it in my book....
08' F250 4x4 w/ 3:55's
bigrpowr is offline
post #4 of 20 (permalink) Old 07-17-2007, 01:20 AM Thread Starter
Re: Trans ?
thanks guys, thats the info I was looking for!
02 F-350 7.3
08 F-250 6.4
98 3500 12v
post #5 of 20 (permalink) Old 07-17-2007, 04:38 AM
Sponsor
VanAackenBrosRacing's Avatar
Send a message via AIM to VanAackenBrosRacing
Re: Trans ?
I would definetly do the full build and be done with it!!!
VanAackenBrosRacing is offline
post #6 of 20 (permalink) Old 07-18-2007, 12:52 AM
AllYourBaseAreBelongToUs
imelmo's Avatar
Re: Trans ?
I've encountered this problem at each major power increase that I've done. Always fixed it with a torque converter. First got a converter from BD which worked well. Then got a full built ATS trans with their 5 Star. I've been sending the converter back here and there to get it loosened up or tightened to work with whatever set-up I run.
EMPIRE DIESEL, PERFORMANCE TRUCK PRODUCTS, CEN-TEX DIESEL PERFORMANCE, AND DIESEL INNOVATIONS
ALSO LOTS OF HELP FROM (IN NO PARTICULAR ORDER) TWISTED DIESEL PERFORMANCE, FCDP, ITP, MATT WITH GEARHEAD, ERIC WITH INNOVATIVE, DOUG WITH GOGO DIESEL, CASS WITH FULL FORCE DIESEL, AND SWAMP'S
2005 F350 Fat-Butt Truck
2004 ECSB Procharged F250
imelmo is offline
post #7 of 20 (permalink) Old 07-18-2007, 01:09 AM
Re: Trans ?
^^ I agree, a converter made a huge difference for me as well. Felt like a different truck. Actually pushed you in the seat when it locked, instead of just revving.
I would get an inline filer on there ASAP so the dying converter doesn't pollute the rest of the trans, plug up the coolers and overheat, etc.
Then get a converter in it if you can't do a full build right now.
If you're savvy, you could consider a DIY while you have it out. Cost savings is substantial.
gregrob is offline
post #8 of 20 (permalink) Old 07-18-2007, 05:15 PM
Banning Smut
PTSUPERD's Avatar
Re: Trans ?
I have had really good luck running a Suncoast convertor and a Transgo tugger kit........until a couple months ago. no issues at all for over 3 years.
Convertor held fine, but I blew up the OD planetary. (from what I was told, the OD I blew was aluminum and should have been steel). While the tranny was out, I went back in with a heavier planetary assembly as well as a billet input shaft from John Wood.
I'm guessing my tranny is holding 450? maybe...
All is well now.
PTSUPERD is offline
post #9 of 20 (permalink) Old 07-18-2007, 05:16 PM
Re: Trans ?
So it's still otherwise stock?
Sweet
gregrob is offline
post #10 of 20 (permalink) Old 07-18-2007, 05:48 PM
Banning Smut
PTSUPERD's Avatar
Re: Trans ?
Sweet
Yes sir.
Oh yeah, I added a 6.0 cooler (at Biggies suggestion). Got it from a buddy for $50. It dropped my temps 35 degrees.
PTSUPERD is offline
