Help what are the syntoms for silon vavle replacement in a trany for a 2001 f-350 7.3 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 10-05-2009, 02:03 AM Thread Starter
Exclamation Help what are the syntoms for silon vavle replacement in a trany for a 2001 f-350 7.3
I might rebuild the tranny but i want to know if my syntoms are just the syloniod vavles it shuts eng off @ idle when i go in rev. and won;t move in fwd ntil 2000 rpm sometime it shift fine though all the gears and when it slipps i just restart the truck and it will work for a little agian does this sound like silionod vavle prob?
spencer4hire is offline
post #2 of 4 (permalink) Old 10-05-2009, 02:48 AM
Failure to Communicate
highfive's Avatar
Re: Help what are the syntoms for silon vavle replacement in a trany for a 2001 f-350
Check the fluid level first. a low level will stall the truck in reverse. Silon's aren't they from Battlestar gellactica ;-)
96 F250 CC SB 4x4
DIY or Die Tryin-Fuel, Trans, Lifted and Stroked
highfive is offline
post #3 of 4 (permalink) Old 10-05-2009, 06:40 AM
Go Away I'm Baitin
fishinfool98's Avatar
Send a message via AIM to fishinfool98
Spencer give me a call tommorow some time after 3 just thought about taking the soleonoid assembly out of the trans thats in the trans that didnt work for me and send it to you and see if that works!
Just to see if that narrows the problem down for you! I will look in my tech manual and see if it can be done while the trans is in the truck without loosing anything!
Or maybe someone else will chime in
06 CCLB SRW grey first mod was PSN sticker
Sailors may come
Sailors may go
Tis the engineer below
That makes it Suck, Push, Bang, and Blow
"Closed due to EXPLOSIVE diarrhea, will be back when the EXPLOSIONS are over!"
fishinfool98 is offline
post #4 of 4 (permalink) Old 10-05-2009, 07:16 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
No, it does not sound like a solenoid problem. It sounds to me like you have some worn internal seals that are causing a lot of leakage. That will make the trans so that it won't move until you rev it in drive, and will cause the torque converter clutch to drift on and stall the engine in reverse. It is also possible that the pump is worn out. That will cause similar symptoms.
You can run a pressure test with a 0-350 PSI gauge in the pressure port in the side of the trans. The Ford shop manual has a pressure chart, I don't have those numbers.
Mark Kovalsky is offline
