2001 f-350 7.3l (tranyprob) shuts eng off in rev. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 10-04-2009, 11:11 PM Thread Starter
Unhappy 2001 f-350 7.3l (tranyprob) shuts eng off in rev.
I don't know if i should rebuild trny, truck wont move fwd until i hit 2000rpm sometimes stalls truck when i go in rev. like its binding up only @ idle revesring i got 120000 miles on it f-350 2001 7.3
spencer4hire is offline
post #2 of 3 (permalink) Old 10-05-2009, 07:19 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: 2001 f-350 7.3l (tranyprob) shuts eng off in rev.
It sounds to me like you have some worn internal seals that are causing a lot of leakage. That will make the trans so that it won't move until you rev it in drive, and will cause the torque converter clutch to drift on and stall the engine in reverse. It is also possible that the pump is worn out. That will cause similar symptoms.
Mark Kovalsky is offline
post #3 of 3 (permalink) Old 10-10-2009, 11:28 AM
Fixing Broken Stuff
toolmangary's Avatar
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
