another e40d question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 03-29-2015, 09:52 PM Thread Starter
I recently purchased my dads truck. Im having a wierd shift around 40 mph after truck and tranny is warm. it will up shift then seem like it down shifts or gradually slides into gear. shifts fine cold. its a 96 psd. My dad had the tranny rebuilt about 10k miles ago. He doesnt pull anything with this truck anymore.
I also notice that the speedo bounces 2 to 4 mph around 35 to 55mph. I read the vss also causes shifting issues so could this be a possibilty?
I hooked up auto enginuity and have no codes. solenoid 1 and 2 seem to shift correctly. not sure if there is a solenoid 3 because values didnt change.
I did notice however the tranny fluid is really high. It is over the hot mark when the tranny is cold.
Could the possible air agitation or overfilling cause that wierd shift?
Also the auto enginuity program monitered tranny temp sensor in volts. Does this tranny even have a factory temp sensor?
94 4 door f350 psd 2wd manual all stock, 97 ext cab f250 psd 4x4 auto. 3in downpipe, 4 in diamond eye exhaust with cat delete, ts performance chip, s&b intake
Last edited by jnkpilgrim; 03-29-2015 at 10:03 PM. Reason: I left out important info for troubleshooting issue
jnkpilgrim is offline
post #2 of 2 (permalink) Old 03-30-2015, 01:18 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: another e40d question
That is a possibility.
Solenoid 3 is the coast clutch solenoid. It will turn on if you press the OD OFF button. It is not causing your problem.
That's meaningless. Checking it cold has no meaning at all. Warm it up and check it.
If it really is overfilled, maybe.
Much more likely is the programming. It wasn't very good in the late 90's. When I worked there I asked to be transferred to that position so I could fix it. That didn't happen.
What is happening is at the start of the 3-4 shift the torque converter clutch is supposed to slip a little bit during the shift. Due to poor programming it releases the clutch, the engine speed rises, the shift happens, and then it relocks. It's ugly. A custom chip is the only way I know to fix this.
Yes it does.
Mark
Mark Kovalsky is offline
