zf trans help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 09-30-2009, 11:56 PM Thread Starter
Question zf trans help
okay i have two zf trans about the same year the problem is one is shot the one that is shot is out of a 97 with a 7.3 the other one is good but from a 351 with the small bellhousing can i unbolt both and just swap the front cases thanks
shawn martin is offline
post #2 of 2 (permalink) Old 10-04-2009, 04:58 AM
oilfield trucker
zpilgeram's Avatar
Re: zf trans help
Yes. But be sure to keep the tag off the other tranny because only the cases are the same. The guts will be different so if you ever need a specific part you will need to refer back to the old tag number. Anytime you order zf parts they will first ask for the serial number that is because they kept making small changes to the trannys over the years.
zpilgeram is offline
