overdrive wont work - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 09-30-2009, 12:49 AM Thread Starter
fordtrucksrule7's Avatar
overdrive wont work
i was driving today going about 70 and all of a sudden the rpms went way up so i let out of it, it was 2600 at 65mph instead of about 2100. i hit the over drive button and turned it off and back on but it wouldnt do anything. the trans temp also climbed up to 220 and i was unloaded and about 65* outside, once i returned home the trans had fell to 190 but went back up to 205. has anyone else expericened this and what was wrong thanks.
fordtrucksrule7 is offline
post #2 of 6 (permalink) Old 09-30-2009, 12:56 AM
original "REZNECK"
kbnord's Avatar
Re: overdrive wont work
what yr truck what tranny. did the light go on and off when you pushed it?
twice tottalled
01 F250 cc 4x4 straight pipe, custom front and rear bumpers, 1 ton rear susp, flatbed, TS Chip, king ranch rims, 315 tires
Originally Posted by Aljay
Since when do 7.3's puke coolant like an overfilled hooker on a busy night ?
kbnord is offline
post #3 of 6 (permalink) Old 09-30-2009, 01:12 AM Thread Starter
o yea i forgot i dont have a sig, 99 4r100. the light seemed to work like normal
post #4 of 6 (permalink) Old 09-30-2009, 04:21 PM
Failure to Communicate
highfive's Avatar
Are you sure it wasn't the converter just unlocking and staying that way?
That would tend to make the temps climb more than just driving in D.
It could be a silly electrical issue make sure to check all the fuses and such both boxes, were you towing anything?
96 F250 CC SB 4x4
DIY or Die Tryin-Fuel, Trans, Lifted and Stroked
highfive is offline
post #5 of 6 (permalink) Old 10-04-2009, 06:04 AM Thread Starter
i think it might be the torque converter, i was driving it again and the it still wont go more then 65mph, and the 2-3 shift takes awhile, the one time it was a good 1/2 mile of going about 25mph at almost 3000rpm. so im hoping its just the tc not anything else, does this sound like symptoms of a bad tc. for the last couple months it has seemed to shutter going up a hill at like 40-45.
post #6 of 6 (permalink) Old 10-04-2009, 11:39 AM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
I can't see how this could be the torque converter. The torque converter has nothing to do with shifting, and you're describing a trans that won't shift.
Mark Kovalsky is offline
